Ana içeriğe geç
DJI Mavic Pro Upper Shell Replacement
Neye ihtiyacın var
  1. DJI Mavic Pro Upper Shell Replacement, Battery: adım 1, 3 resimden 1. DJI Mavic Pro Upper Shell Replacement, Battery: adım 1, 3 resimden 2. DJI Mavic Pro Upper Shell Replacement, Battery: adım 1, 3 resimden 3.
    • Grab both sides of the battery.
    • Pinch the releasing buttons on both sides of the battery.
    • Lift the battery up and out.
  2. DJI Mavic Pro Upper Shell Replacement, Upper Shell: adım 2, 1 resimden 1.
    • Remove the six 5mm 1.5 Hex screws by turning the screwdriver counterclockwise.
  3. DJI Mavic Pro Upper Shell Replacement: adım 3, 1 resimden 1.
    • Flip the drone over so that the gimbal is facing up.
    • Remove the two 4mm 1.5 Hex screws near the gimbal case by turning the screwdriver counterclockwise.
    • Remove the two 5mm 1.5 Hex screws near the gimbal case by turning the screwdriver counterclockwise.
  4. DJI Mavic Pro Upper Shell Replacement: adım 4, 1 resimden 1.
    Bu adımda kullanılan alet:
    • Remove the two small panel pieces near the gimbal case with the tweezers.
  5. DJI Mavic Pro Upper Shell Replacement: adım 5, 1 resimden 1.
    • Remove the two 5mm 1.5 Hex screws and two PH000 screws that are under the panel pieces by turning the respective screwdrivers counterclockwise.
  6. DJI Mavic Pro Upper Shell Replacement: adım 6, 1 resimden 1.
    • Flip the drone back over so the upper shell is facing up.
    • Pry off the upper shell with a nylon spudger.
    • Be careful when prying with the spudger because you could damage the upper shell's plastic tabs.
  7. DJI Mavic Pro Upper Shell Replacement: adım 7, 1 resimden 1.
    • Remove the white connector at the back of the flight controller board by gently pulling at the base.
Sonuç
6 farklı kişi bu kılavuzu tamamladı.
Mondona Behroozian
1.691 İtibar
2 adet Kılavuz yazıldı
Ekip
Cal Poly, Team S17-G3, White Fall 2018 Cal Poly, Team S17-G3, White Fall 2018 üyesi
CPSU-WHITE-F18S17G3
4 Üyeler
20 adet Kılavuz yazıldı
2Kılavuz Yorumları
Well done, good instructions - are the two screws under the tabs shorter than the others from the shell?
Lazaro Hernandez - Yanıt
Awesome descriptions were perfect except for saying there is 4 acres to be removed under the tabs behind the gimbal. Theirs only 2
shaun.cunningham - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 13
Son 30 gün: 64
Her zaman: 6,198
