Ana içeriğe geç
DJI Mini 2 SE Battery Cover Replacement
Neye ihtiyacın var
  1. DJI Mini 2 SE Battery Cover Replacement, Doing this will void your warranty!: adım 1, 1 resimden 1.
    • When opening the drone, this seal will break, DO THIS AT YOUR OWN RISK.
  2. DJI Mini 2 SE Battery Cover Replacement, Remove The Battery: adım 2, 1 resimden 1.
    • Simple Step.
    • Ignore the low quality video
  3. DJI Mini 2 SE Battery Cover Replacement, Prying Up: adım 4, 2 resimden 1. DJI Mini 2 SE Battery Cover Replacement, Prying Up: adım 4, 2 resimden 2.
    • Insert an opening pick
    • Go around the drone. Carefully going around prying up.
  4. DJI Mini 2 SE Battery Cover Replacement, Lift up the upper case: adım 5, 2 resimden 1. DJI Mini 2 SE Battery Cover Replacement, Lift up the upper case: adım 5, 2 resimden 2.
    • Be careful not to touch any of the components.
  5. DJI Mini 2 SE Battery Cover Replacement, Finding The Clips: adım 6, 3 resimden 1. DJI Mini 2 SE Battery Cover Replacement, Finding The Clips: adım 6, 3 resimden 2. DJI Mini 2 SE Battery Cover Replacement, Finding The Clips: adım 6, 3 resimden 3.
    • Find the clips on the top cover.
    • Find the clips on the battery cover.
  6. DJI Mini 2 SE Battery Cover Replacement, Clipping them together: adım 7, 1 resimden 1.
    • It should look like this.
  7. DJI Mini 2 SE Battery Cover Replacement, Putting the top cover back on: adım 8, 2 resimden 1. DJI Mini 2 SE Battery Cover Replacement, Putting the top cover back on: adım 8, 2 resimden 2.
    • Push down on all of the clips around the drone with medium pressure.
  8. DJI Mini 2 SE Battery Cover Replacement, Putting in the screws: adım 9, 1 resimden 1.
    • Don't put them in too tight
    • Put the battery in and test if it closes
Sonuç
Bir başkası bu kılavuzu tamamladı.
Jordan
232 İtibar
1 Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 6
Son 7 gün: 108
Son 30 gün: 145
Her zaman: 551
