Ana içeriğe geç
Bu teardown bir tamir kılavuzu değildir. DJI Mini 3 cihazınızı onarmak için, servis kılavuzumuzu kullanın.
  1. DJI Mini 3 Chip ID, Drone Main Board Side A: adım 1, 2 resimden 1. DJI Mini 3 Chip ID, Drone Main Board Side A: adım 1, 2 resimden 2.
    • Ambarella H22-A0-RH H22 quad-core video SoC
    • Kingston D1216ECMDXGME-U 256 MB DDR3L SDRAM memory
    • HDSC HC32F460JEUA 32-bit ARM Cortex-M4 microcontroller
    • Qualcomm SMB2352–207 dual-cell Li-ion battery charger
    • Monolithic Power Systems MP6507GQ stepper motor driver w/ MOSFETs
    • Silergy SY6280AAC power distribution switch
    • OmniVision WAS7222Q 480 Mbps DPDT analog switch
  2. DJI Mini 3 Chip ID: adım 2, 1 resimden 1.
    • Texas Instruments TLV75901P 1 A / adj. LDO regulator
    • OmniVision WL2836D12 300 mA / 1.2 V LDO regulator
    • OmniVision WL2836D18 300 mA / 1.8 V LDO regulator
    • OmniVision WL2848D18 300 mA / 1.8 V LDO regulator
    • OmniVision WL2836D25 300 mA / 2.5 V LDO regulator
    • Nexperia 74LVC2T45 dual supply translating transceiver
    • Nexperia 74LVC1G08 single 2-input AND gate
  3. DJI Mini 3 Chip ID: adım 3, 1 resimden 1.
    • Yangjie Electronic Technology YJQ1216A P-Channel MOSFET
  4. DJI Mini 3 Chip ID, Drone Main Board Side A - Radio: adım 4, 1 resimden 1.
    • Possibly Leadcore S1 RF transceiver
    • Kangxi Communication Technologies KCT8247HE-1 2.4 GHz WLAN front-end module
    • Kangxi Communication Technologies KCT8576N 5 GHz WLAN front-end module
    • Likely Maxscend MXDx213 low noise amplifier
    • Likely Maxscend DPDT RF switch
    • Likely Maxscend MXD8622E SPDT RF switch
  5. DJI Mini 3 Chip ID, Drone Main Board Side B: adım 5, 2 resimden 1. DJI Mini 3 Chip ID, Drone Main Board Side B: adım 5, 2 resimden 2.
    • NXP Semiconductor MIMXRT1064DVL6B i.MX single core application processor
    • Kioxia TC58NVG1S3HBAI6 256 MB NAND flash memory
    • Monolithic Power Systems MP6543HGL 3-phase power stage
    • Silicon Content Technology SCT2260A 6 A synchronous step-down DC-DC converter
    • Silicon Content Technology SCT2230 3 A synchronous step-down DC-DC converter
    • Monolithic Power Systems DC-DC Converter
  6. DJI Mini 3 Chip ID: adım 6, 1 resimden 1.
    • Possibly Linearin LTP3330 300 mA / 3.0 V LDO Regulator
    • OmniVision WL2836D33 300 mA / 3.3 V LDO regulator
  7. DJI Mini 3 Chip ID, Drone Main Board Side B - Radio: adım 7, 1 resimden 1.
    • Synaptics SYN43456PXKUBG single-chip 5G WiFi 802.11ac w/ Bluetooth 5 & FM receiver
  8. DJI Mini 3 Chip ID, Distance Sensor Board Side A: adım 8, 2 resimden 1. DJI Mini 3 Chip ID, Distance Sensor Board Side A: adım 8, 2 resimden 2.
  9. DJI Mini 3 Chip ID, Distance Sensor Board Side B: adım 9, 2 resimden 1. DJI Mini 3 Chip ID, Distance Sensor Board Side B: adım 9, 2 resimden 2.
    • Texas Instruments OPT3101 distance sensor analog front-end
    • SG Micro SGM2036-1.2 300 mA / 1.2 V LDO regulator
    • SG Micro SGM2036-1.8 300 mA / 1.8 V LDO regulator
    • SG Micro SGM2036-2.8 300 mA / 2.8 V LDO regulator
  10. DJI Mini 3 Chip ID, GNSS Receiver Board Side A: adım 10, 2 resimden 1. DJI Mini 3 Chip ID, GNSS Receiver Board Side A: adım 10, 2 resimden 2.
    • TDK-InvenSense ICM-40609-D 6-axis MEMS accelerometer & gyroscope
    • Goertek SPL06-001 pressure and temperature sensor
  11. DJI Mini 3 Chip ID, GNSS Receiver Board Side B: adım 11, 2 resimden 1. DJI Mini 3 Chip ID, GNSS Receiver Board Side B: adım 11, 2 resimden 2.
    • u-blox UBX-M10050-KB GNSS receiver
    • Maxscend MXDLN16TP GNSS low noise amplifier
  12. DJI Mini 3 Chip ID, GNSS Receiver Board Side B - Filters: adım 12, 1 resimden 1.
  13. DJI Mini 3 Chip ID, Motor Controller Board Side A: adım 13, 2 resimden 1. DJI Mini 3 Chip ID, Motor Controller Board Side A: adım 13, 2 resimden 2.
    • Texas Instruments DRV8328B 3-phase BLDC gate driver
  14. DJI Mini 3 Chip ID, Motor Controller Board Side B: adım 14, 2 resimden 1. DJI Mini 3 Chip ID, Motor Controller Board Side B: adım 14, 2 resimden 2.
    • Spintrol SPC1168APE48 32-bit ARM Cortex-M4 microcontroller
    • Vergiga VS3622DB 30 V dual N-channel MOSFET
  15. DJI Mini 3 Chip ID, Sensor Flex Side A: adım 15, 2 resimden 1. DJI Mini 3 Chip ID, Sensor Flex Side A: adım 15, 2 resimden 2.
  16. DJI Mini 3 Chip ID, Battery Board Side A: adım 16, 2 resimden 1. DJI Mini 3 Chip ID, Battery Board Side A: adım 16, 2 resimden 2.
    • Texas Instruments BQ9003 battery fuel gauge (likely)
    • Advanced Power Electronics Corp. AP3N1R8MT 30 V N-channel MOSFET
  17. DJI Mini 3 Chip ID, Block Diagram: adım 17, 2 resimden 1. DJI Mini 3 Chip ID, Block Diagram: adım 17, 2 resimden 2.
    • Predicted block diagram primarily based on available datasheets and observed implementation in product.
CChin
6.899 İtibar
7 adet Kılavuz yazıldı
2 Yorum
Perfect sharing
BEKTAŞ KANTEMİR - Yanıt
It's great. Thank you. Did you also disassemble the dji mini4 or mini4 pro like that?
albert - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 26
Son 7 gün: 106
Son 30 gün: 371
Her zaman: 4,442
