Ana içeriğe geç
DJI Phantom 2 Vision+ Propellers Removal
Neye ihtiyacın var
  1. DJI Phantom 2 Vision+ Propellers Removal, Remove the battery: adım 1, 3 resimden 1. DJI Phantom 2 Vision+ Propellers Removal, Remove the battery: adım 1, 3 resimden 2. DJI Phantom 2 Vision+ Propellers Removal, Remove the battery: adım 1, 3 resimden 3.
    • Pinch the top and bottom tabs of the battery case, pull the battery straight out to remove it.
    • The metal connectors form a stiff mechanical connection with the battery, you will need quite a bit of force to remove the battery. Hold the Phantom Vision+ with one hand and remove the battery with the other.
    FixBot'a Sor
    Yorum Ekle
  2. DJI Phantom 2 Vision+ Propellers Removal, Propellers: adım 2, 1 resimden 1.
    • Determine if the propellor is clockwise or counter-clockwise rotating.
    • Each arm is labeled with a rotation icon that shows the direction of propellor rotation.
    • If this icon is missing or you can't read it, you can determine the direction of rotation by examining the propellor.
    • A clockwise rotating propellor pushes air down while rotating clockwise, and the opposite is true for a counter-clockwise rotating propellor, and the propellor blade slopes up in the direction of rotation.
    FixBot'a Sor
    Yorum Ekle
  3. DJI Phantom 2 Vision+ Propellers Removal, Removing clockwise rotating propellers: adım 3, 3 resimden 1. DJI Phantom 2 Vision+ Propellers Removal, Removing clockwise rotating propellers: adım 3, 3 resimden 2. DJI Phantom 2 Vision+ Propellers Removal, Removing clockwise rotating propellers: adım 3, 3 resimden 3.
    • Loosen a clockwise rotating propeller by holding the motor with one hand and spinning the propellor clockwise.
    • Remove the propellor.
    FixBot'a Sor
    Yorum Ekle
  4. DJI Phantom 2 Vision+ Propellers Removal, Removing counter-clockwise rotating propellers: adım 4, 3 resimden 1. DJI Phantom 2 Vision+ Propellers Removal, Removing counter-clockwise rotating propellers: adım 4, 3 resimden 2. DJI Phantom 2 Vision+ Propellers Removal, Removing counter-clockwise rotating propellers: adım 4, 3 resimden 3.
    • Loosen a counter-clockwise rotating propeller by holding the motor with one hand and spinning the propellor counter-clockwise.
    FixBot'a Sor
    Yorum Ekle
Sonuç
5 farklı kişi bu kılavuzu tamamladı.
David Hoyt
4.053 İtibar
39 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 25-89, Amido Spring 2010 Cal Poly, Team 25-89, Amido Spring 2010 üyesi
CPSU-AMIDO-S10S25G89
4 Üyeler
59 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 4
Son 7 gün: 14
Son 30 gün: 57
Her zaman: 7,531
