Giriş
This guide demonstrates how to replace the gimbal housing of your DJI Phantom 2 Vision. When completing the disassembly make sure to clean any residue that may be surrounding the screws before beginning, as doing this will ensure no over or under-tightening of screws may occur. Also, make sure to verify the size of the screws if you plan on replacing them, they are 6mm.
Note: The drone we worked on already had the propellers removed. However, you will need to remove the propellers before Step 4. Refer to the DJI Phantom 2 Vision+ Propellers Removal for detailed instructions, as the process is identical.
Neye ihtiyacın var
The battery is located on the backside of the drone. You will see a large rectangular indent protruding outward.
Flip the drone over so the bottom is facing up.
Use a Phillips #00 screwdriver to remove the four 6 mm screws.
To access the screws, slowly pull back on the mount in the opposite direction.
