Giriş
The landing gear on the DJI Phantom 2 Vision supports the drone during takeoff, landing, and while at rest. Over time, the landing gear may become cracked, bent, or unusable due to hard landings, crashes, or other wear and tear. Damaged landing gear can affect the drone's balance and may interfere with the camera gimbal if not repaired.
This guide will walk you through the process of removing and replacing the landing gear assembly on your DJI Phantom 2 Vision. Before beginning this repair, make sure the drone is powered off and the battery is removed to prevent accidental startup or electrical damage.
Neye ihtiyacın var
The battery is located on the backside of the drone. You will see a large rectangular indent protruding outward.
Flip the drone over so the bottom is facing up.
Use a Phillips #00 screwdriver to remove the four 6 mm screws.
To access the screws, slowly pull back on the mount in the opposite direction.
Locate Landing Gear Assembly.
Turn the drone upside down to access the landing gear located on the bottom of the device.
