Giriş
Follow this video guide to decrease interference from the Wifi module and increase GPS signal strength.
The guide instructions are written, and the only audio is music, and will not be suitable for the visually impaired. You can follow our case top shell guide to remove the cover, and watch the video to learn how to move the GPS cable and add shielding.
Neye ihtiyacın var
Videoya Genel Bakış
Remove the following screws from the underside of the Phantom:
Twelve 2.0 mm hex bolts
Four Phillips #00 screws
The GPS cable molex connector is located on the backside of the mainboard, near the battery opening.
Pull the GPS connector straight up out of its socket.
Lift the top shell case up and remove it from the body of the Phantom.
4 farklı kişi bu kılavuzu tamamladı.
3 Yorum
hello do you still help with phantom drones
do you still help with drones/
Isn't it better to connect the aluminium foil to the GPS GND for better isolation?
