Ana içeriğe geç
DJI Phantom 2 Vision Plus GPS Signal Improvement Technique
Neye ihtiyacın var
Videoya Genel Bakış
  1. DJI Phantom 2 Vision Plus GPS Signal Improvement Technique, Case Top Shell: adım 1, 2 resimden 1. DJI Phantom 2 Vision Plus GPS Signal Improvement Technique, Case Top Shell: adım 1, 2 resimden 2.
    • Remove the following screws from the underside of the Phantom:
    • Twelve 2.0 mm hex bolts
    • Four Phillips #00 screws
    FixBot'a Sor
    Yorum Ekle
  2. DJI Phantom 2 Vision Plus GPS Signal Improvement Technique: adım 2, 2 resimden 1. DJI Phantom 2 Vision Plus GPS Signal Improvement Technique: adım 2, 2 resimden 2.
    • Gently lift up the top shell case.
    • Do not attempt to fully remove the top shell. The GPS cable is still attached to the mainboard, avoid lifting the case too high or you may damage this connection.
    FixBot'a Sor
    Yorum Ekle
  3. DJI Phantom 2 Vision Plus GPS Signal Improvement Technique, Unplug GPS connector and remove case: adım 3, 3 resimden 1. DJI Phantom 2 Vision Plus GPS Signal Improvement Technique, Unplug GPS connector and remove case: adım 3, 3 resimden 2. DJI Phantom 2 Vision Plus GPS Signal Improvement Technique, Unplug GPS connector and remove case: adım 3, 3 resimden 3.
    • The GPS cable molex connector is located on the backside of the mainboard, near the battery opening.
    • Pull the GPS connector straight up out of its socket.
    • Lift the top shell case up and remove it from the body of the Phantom.
    FixBot'a Sor
    Yorum Ekle
Sonuç
4 farklı kişi bu kılavuzu tamamladı.
Sam Goldheart
477.388 İtibar
538 adet Kılavuz yazıldı
Ekip
iFixit iFixit üyesi
Staff
122 Üyeler
25.930 adet Kılavuz yazıldı
3Kılavuz Yorumları
hello do you still help with phantom drones
George Aguirre - Yanıt Paylaş
do you still help with drones/
Isn't it better to connect the aluminium foil to the GPS GND for better isolation?
Bruno Duarte - Yanıt Paylaş
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 4
Son 30 gün: 31
Her zaman: 4,967
