Ana içeriğe geç
DJI Phantom 4 Advanced Remote Controller Back Buttons Replacement
Neye ihtiyacın var
  1. DJI Phantom 4 Advanced Remote Controller Back Buttons Replacement, Back Panel: adım 1, 1 resimden 1.
    • Remove the four screws with a Torx T8 screwdriver to access the back con board.
  2. DJI Phantom 4 Advanced Remote Controller Back Buttons Replacement: adım 2, 2 resimden 1. DJI Phantom 4 Advanced Remote Controller Back Buttons Replacement: adım 2, 2 resimden 2.
    • Remove three screws using a Phillips #00 screwdriver.
  3. DJI Phantom 4 Advanced Remote Controller Back Buttons Replacement: adım 3, 2 resimden 1. DJI Phantom 4 Advanced Remote Controller Back Buttons Replacement: adım 3, 2 resimden 2.
    • With tweezers, gently remove the large con board tab.
    • Use your hands to remove the two small clips. Pull out from the socket, in a horizontal direction.
  4. DJI Phantom 4 Advanced Remote Controller Back Buttons Replacement: adım 4, 2 resimden 1. DJI Phantom 4 Advanced Remote Controller Back Buttons Replacement: adım 4, 2 resimden 2.
    • Peel off the rubber grips to access the screw holes.
    • Make sure to save your grips and do not to get them stuck to anything, you are going to want to save the adhesive.
    • Remove the back board and set it aside.
  5. DJI Phantom 4 Advanced Remote Controller Back Buttons Replacement: adım 5, 2 resimden 1. DJI Phantom 4 Advanced Remote Controller Back Buttons Replacement: adım 5, 2 resimden 2.
    • Pull apart the back plastic panel.
    • Recommended tool for this would be the metal spudger, but not required.
    • Once the back panel is off, you will have access to the motherboard.
  6. DJI Phantom 4 Advanced Remote Controller Back Buttons Replacement, Back Buttons: adım 6, 2 resimden 1. DJI Phantom 4 Advanced Remote Controller Back Buttons Replacement, Back Buttons: adım 6, 2 resimden 2.
    • Using a Phillips #00 screwdriver, remove the four screws on the inside of the panel. That will allow you to remove the buttons by gently lifting them with your hands.
  7. DJI Phantom 4 Advanced Remote Controller Back Buttons Replacement: adım 7, 1 resimden 1.
    • Remove back buttons and replace with new ones.
Sonuç
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 5
Her zaman: 418
