Ana içeriğe geç
DJI Phantom 4 Advanced Remote Controller Back Buttons Replacement
Neye ihtiyacın var
    1. DJI Phantom 4 Advanced Remote Controller Back Buttons Replacement, Back Panel: adım 1, 1 resimden 1.
      • Remove the four screws with a Torx T8 screwdriver to access the back con board.
      FixBot'a Sor
      Yorum Ekle
    2. DJI Phantom 4 Advanced Remote Controller Back Buttons Replacement: adım 2, 2 resimden 1. DJI Phantom 4 Advanced Remote Controller Back Buttons Replacement: adım 2, 2 resimden 2.
      • Remove three screws using a Phillips #00 screwdriver.
      FixBot'a Sor
      Yorum Ekle
    3. DJI Phantom 4 Advanced Remote Controller Back Buttons Replacement: adım 3, 2 resimden 1. DJI Phantom 4 Advanced Remote Controller Back Buttons Replacement: adım 3, 2 resimden 2.
      Bu adımda kullanılan alet:
      • With tweezers, gently remove the large con board tab.
      • Use your hands to remove the two small clips. Pull out from the socket, in a horizontal direction.
      FixBot'a Sor
      Yorum Ekle
    4. DJI Phantom 4 Advanced Remote Controller Back Buttons Replacement: adım 4, 2 resimden 1. DJI Phantom 4 Advanced Remote Controller Back Buttons Replacement: adım 4, 2 resimden 2.
      • Peel off the rubber grips to access the screw holes.
      • Make sure to save your grips and do not to get them stuck to anything, you are going to want to save the adhesive.
      • Remove the back board and set it aside.
      FixBot'a Sor
      Yorum Ekle
    5. DJI Phantom 4 Advanced Remote Controller Back Buttons Replacement: adım 5, 2 resimden 1. DJI Phantom 4 Advanced Remote Controller Back Buttons Replacement: adım 5, 2 resimden 2.
      • Pull apart the back plastic panel.
      • Recommended tool for this would be the metal spudger, but not required.
      • Once the back panel is off, you will have access to the motherboard.
      FixBot'a Sor
      Yorum Ekle
    1. DJI Phantom 4 Advanced Remote Controller Back Buttons Replacement, Back Buttons: adım 6, 2 resimden 1. DJI Phantom 4 Advanced Remote Controller Back Buttons Replacement, Back Buttons: adım 6, 2 resimden 2.
      • Using a Phillips #00 screwdriver, remove the four screws on the inside of the panel. That will allow you to remove the buttons by gently lifting them with your hands.
      FixBot'a Sor
      Yorum Ekle
    2. DJI Phantom 4 Advanced Remote Controller Back Buttons Replacement: adım 7, 1 resimden 1.
      • Remove back buttons and replace with new ones.
      FixBot'a Sor
      Yorum Ekle
Sonuç
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 3
Son 7 gün: 10
Son 30 gün: 46
Her zaman: 827
