Bu kılavuzda güncel değişiklikler var. En son onaylanmamış sürüme geçin.
Giriş
The ultrasonic sensors use sound waves to help position the drone in three-dimensional space. If your DJI drone experiences either erratic flight behavior or the inability to hold its position when staying still in the air your ultrasonic sensors may need to be replaced.
Neye ihtiyacın var
Use your finger tips to pinch the damaged propeller.
Twist the propeller counterclockwise and pull up to remove.
Remove the eight 7 mm hex screws by turning counterclockwise with a 2 mm hex bit.
Bir başkası bu kılavuzu tamamladı.
