Ana içeriğe geç
DJI Phantom Battery Replacement
Neye ihtiyacın var
  1. DJI Phantom Battery Replacement, Open the Battery Compartment: adım 1, 3 resimden 1. DJI Phantom Battery Replacement, Open the Battery Compartment: adım 1, 3 resimden 2. DJI Phantom Battery Replacement, Open the Battery Compartment: adım 1, 3 resimden 3.
    • Press down on battery door release tab to flip the battery door open.
  2. DJI Phantom Battery Replacement, Remove the Battery: adım 2, 3 resimden 1. DJI Phantom Battery Replacement, Remove the Battery: adım 2, 3 resimden 2. DJI Phantom Battery Replacement, Remove the Battery: adım 2, 3 resimden 3.
    • Pull out the battery pack.
    • Avoid pulling on the battery wires, excess stress may break the wires, damage the power connectors, or crack the internal solder joints.
  3. DJI Phantom Battery Replacement, Disconnect the Battery: adım 3, 2 resimden 1. DJI Phantom Battery Replacement, Disconnect the Battery: adım 3, 2 resimden 2.
    • Pull the two halves of the XT60 power connector apart.
    • It's a tight fit, so be careful not to hit your drone or yank on the cables when it releases!
Sonuç
Bir başkası bu kılavuzu tamamladı.
David Hoyt
4.053 İtibar
41 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 25-89, Amido Spring 2010 Cal Poly, Team 25-89, Amido Spring 2010 üyesi
CPSU-AMIDO-S10S25G89
4 Üyeler
61 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 3
Son 7 gün: 10
Son 30 gün: 14
Her zaman: 2,632
