Neye ihtiyacın var
Remove the following screws from the underside of the drone:
Twelve 2.0 mm hex screws
Four Phillips #0 screws
Loosen the cable from the plastic landing gear.
Unplug the magnetometer molex connector.
Lift the GPS cable molex connector up out of its socket on the main board.
Gently pull the slack of the magnetometer cable through the case bottom shell.
The case top shell should now have enough slack to work on the interior of the Phantom.
