Ana içeriğe geç
DJI Phantom Propeller Replacement
Neye ihtiyacın var
  1. DJI Phantom Propeller Replacement, Open the Battery Compartment: adım 1, 3 resimden 1. DJI Phantom Propeller Replacement, Open the Battery Compartment: adım 1, 3 resimden 2. DJI Phantom Propeller Replacement, Open the Battery Compartment: adım 1, 3 resimden 3.
    • Press down on battery door release tab to flip the battery door open.
  2. DJI Phantom Propeller Replacement, Remove the Battery: adım 2, 3 resimden 1. DJI Phantom Propeller Replacement, Remove the Battery: adım 2, 3 resimden 2. DJI Phantom Propeller Replacement, Remove the Battery: adım 2, 3 resimden 3.
    • Pull out the battery pack.
    • Avoid pulling on the battery wires, excess stress may break the wires, damage the power connectors, or crack the internal solder joints.
  3. DJI Phantom Propeller Replacement, Disconnect the Battery: adım 3, 2 resimden 1. DJI Phantom Propeller Replacement, Disconnect the Battery: adım 3, 2 resimden 2.
    • Pull the two halves of the XT60 power connector apart.
    • It's a tight fit, so be careful not to hit your drone or yank on the cables when it releases!
  4. DJI Phantom Propeller Replacement, Identifying Silver and Black Collets: adım 4, 2 resimden 1. DJI Phantom Propeller Replacement, Identifying Silver and Black Collets: adım 4, 2 resimden 2.
    • Silver-topped propeller collets unscrew counter-clockwise
    • Black-topped propeller collets unscrew clockwise
  5. DJI Phantom Propeller Replacement, Unscrewing Silver Collets: adım 5, 3 resimden 1. DJI Phantom Propeller Replacement, Unscrewing Silver Collets: adım 5, 3 resimden 2. DJI Phantom Propeller Replacement, Unscrewing Silver Collets: adım 5, 3 resimden 3.
    • For propellors with silver collets: Use a 12 mm wrench or socket to loosen silver collets in the counter-clockwise direction.
    • Once free, unscrew and remove the collet.
  6. DJI Phantom Propeller Replacement, Unscrewing Black Collets: adım 6, 3 resimden 1. DJI Phantom Propeller Replacement, Unscrewing Black Collets: adım 6, 3 resimden 2. DJI Phantom Propeller Replacement, Unscrewing Black Collets: adım 6, 3 resimden 3.
    • For propellors with black collets: Use a 12 mm wrench or socket to loosen black collets in the clockwise direction.
  7. DJI Phantom Propeller Replacement, Remove the Propeller: adım 7, 3 resimden 1. DJI Phantom Propeller Replacement, Remove the Propeller: adım 7, 3 resimden 2. DJI Phantom Propeller Replacement, Remove the Propeller: adım 7, 3 resimden 3.
    • Gently press down the motor shaft and lift the propeller up to remove it.
Sonuç
David Hoyt
4.053 İtibar
41 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 25-89, Amido Spring 2010 Cal Poly, Team 25-89, Amido Spring 2010 üyesi
CPSU-AMIDO-S10S25G89
4 Üyeler
61 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 2
Son 30 gün: 5
Her zaman: 1,308
