Ana içeriğe geç
DJI Spark Controller Mobile Device Grip Replacement
Neye ihtiyacın var
  1. DJI Spark Controller Mobile Device Grip Replacement, Mobile Device Grip: adım 1, 1 resimden 1.
    • Unfold the arm.
    • Extend the controller’s arm as you would before normally flying the drone.
    • To avoid obstruction, make sure the screwheads of the grip are parallel to the body of the controller.
  2. DJI Spark Controller Mobile Device Grip Replacement: adım 2, 3 resimden 1. DJI Spark Controller Mobile Device Grip Replacement: adım 2, 3 resimden 2. DJI Spark Controller Mobile Device Grip Replacement: adım 2, 3 resimden 3.
    • Remove the grip.
    • Remove two screws using a T6 torx screwdriver.
    • Use this same procedure for both arms.
  3. DJI Spark Controller Mobile Device Grip Replacement: adım 3, 2 resimden 1. DJI Spark Controller Mobile Device Grip Replacement: adım 3, 2 resimden 2.
    • Once both screws are removed, the grip parts come off easily.
    • Be carful when doing this step because the two parts of the grip might fall once the two screws are removed.
Sonuç
Amelia Hagberg
445 İtibar
3 adet Kılavuz yazıldı
Ekip
UMass Dartmouth, Team S1-G7, Botvin Fall 2019 UMass Dartmouth, Team S1-G7, Botvin Fall 2019 üyesi
UMASSD-BOTVIN-F19S1G7
3 Üyeler
7 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 2
Son 30 gün: 6
Her zaman: 700
