Ana içeriğe geç
DJI Spark Cooling Fan Replacement
Neye ihtiyacın var
  1. DJI Spark Cooling Fan Replacement, Propellers: adım 1, 1 resimden 1.
    • Push down on the propeller that is being replaced.
  2. DJI Spark Cooling Fan Replacement: adım 2, 2 resimden 1. DJI Spark Cooling Fan Replacement: adım 2, 2 resimden 2.
    • Twist the propeller until it feels loose.
    • Pull on it until it comes off.
  3. DJI Spark Cooling Fan Replacement, Battery: adım 3, 3 resimden 1. DJI Spark Cooling Fan Replacement, Battery: adım 3, 3 resimden 2. DJI Spark Cooling Fan Replacement, Battery: adım 3, 3 resimden 3.
    • Flip the drone over.
    • Grip the left and right sides of the battery.
    • Slide firmly forward until it pops out.
  4. DJI Spark Cooling Fan Replacement, Lid: adım 4, 3 resimden 1. DJI Spark Cooling Fan Replacement, Lid: adım 4, 3 resimden 2. DJI Spark Cooling Fan Replacement, Lid: adım 4, 3 resimden 3.
    • Remove the four 1.5mm Hex screws.
    • Remove the two 1.5mm Hex screws near the camera head.
    • You may need to remove plastic nubs from the hex screws using a spudger first.
  5. DJI Spark Cooling Fan Replacement: adım 5, 3 resimden 1. DJI Spark Cooling Fan Replacement: adım 5, 3 resimden 2. DJI Spark Cooling Fan Replacement: adım 5, 3 resimden 3.
    • Hold the drone so the lid is facing up.
    • Insert the plastic opening tool into the side of the drone.
    • Slide the tool around the perimeter until you can lift the top off.
  6. DJI Spark Cooling Fan Replacement, Cooling Fan: adım 6, 3 resimden 1. DJI Spark Cooling Fan Replacement, Cooling Fan: adım 6, 3 resimden 2. DJI Spark Cooling Fan Replacement, Cooling Fan: adım 6, 3 resimden 3.
    • Remove the fan.
    • It is attached to the motherboard with several pieces of adhesive.
  7. DJI Spark Cooling Fan Replacement: adım 7, 2 resimden 1. DJI Spark Cooling Fan Replacement: adım 7, 2 resimden 2.
    • Trace the fan wires to the side of the panel.
    • Unplug the wire from its connector.
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
Uzochi Anyanwu
450 İtibar
4 adet Kılavuz yazıldı
Ekip
UMass Dartmouth, Team S1-G7, Botvin Fall 2019 UMass Dartmouth, Team S1-G7, Botvin Fall 2019 üyesi
UMASSD-BOTVIN-F19S1G7
3 Üyeler
7 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 3
Son 30 gün: 15
Her zaman: 1,466
