Ana içeriğe geç
DJI Spark Internal GPS Replacement
Neye ihtiyacın var
    1. DJI Spark Internal GPS Replacement, Propellers: adım 1, 1 resimden 1.
      • Push down on the propeller that is being replaced.
      FixBot'a Sor
      Yorum Ekle
    2. DJI Spark Internal GPS Replacement: adım 2, 2 resimden 1. DJI Spark Internal GPS Replacement: adım 2, 2 resimden 2.
      • Twist the propeller until it feels loose.
      • Pull on it until it comes off.
      FixBot'a Sor
      Yorum Ekle
    1. DJI Spark Internal GPS Replacement, Battery: adım 3, 3 resimden 1. DJI Spark Internal GPS Replacement, Battery: adım 3, 3 resimden 2. DJI Spark Internal GPS Replacement, Battery: adım 3, 3 resimden 3.
      • Flip the drone over.
      • Grip the left and right sides of the battery.
      • Slide firmly forward until it pops out.
      FixBot'a Sor
      Yorum Ekle
    1. DJI Spark Internal GPS Replacement, Lid: adım 4, 3 resimden 1. DJI Spark Internal GPS Replacement, Lid: adım 4, 3 resimden 2. DJI Spark Internal GPS Replacement, Lid: adım 4, 3 resimden 3.
      • Remove the four 1.5mm Hex screws.
      • Remove the two 1.5mm Hex screws near the camera head.
      • You may need to remove plastic nubs from the hex screws using a spudger first.
      FixBot'a Sor
      Yorum Ekle
    2. DJI Spark Internal GPS Replacement: adım 5, 3 resimden 1. DJI Spark Internal GPS Replacement: adım 5, 3 resimden 2. DJI Spark Internal GPS Replacement: adım 5, 3 resimden 3.
      • Hold the drone so the lid is facing up.
      • Insert the plastic opening tool into the side of the drone.
      • Slide the tool around the perimeter until you can lift the top off.
      FixBot'a Sor
      Yorum Ekle
    1. DJI Spark Internal GPS Replacement, GPS: adım 6, 2 resimden 1. DJI Spark Internal GPS Replacement, GPS: adım 6, 2 resimden 2.
      • Identify the GPS module on the motherboard.
      • The GPS module will be labeled as ‘DJI G116’.
      FixBot'a Sor
      Yorum Ekle
    2. DJI Spark Internal GPS Replacement: adım 7, 2 resimden 1. DJI Spark Internal GPS Replacement: adım 7, 2 resimden 2.
      • Remove the four 6.0 mm Phillips #000 screws holding the GPS module to the motherboard.
      FixBot'a Sor
      Yorum Ekle
    3. DJI Spark Internal GPS Replacement: adım 8, 2 resimden 1. DJI Spark Internal GPS Replacement: adım 8, 2 resimden 2.
      • Pick up the GPS module.
      • Carefully disconnect the GPS module ribbon cable from the motherboard.
      • Remove the GPS module.
      FixBot'a Sor
      Yorum Ekle
Sonuç
3 farklı kişi bu kılavuzu tamamladı.
Amelia Hagberg
502 İtibar
3 adet Kılavuz yazıldı
Ekip
UMass Dartmouth, Team S1-G7, Botvin Fall 2019 UMass Dartmouth, Team S1-G7, Botvin Fall 2019 üyesi
UMASSD-BOTVIN-F19S1G7
3 Üyeler
7 adet Kılavuz yazıldı
5Kılavuz Yorumları
How About Spark's Wifi can't find?
Mark Ryan Fontelar - Yanıt Paylaş
GPS module ribbon cable is broken where can i buy?
manzoorsp67 - Yanıt Paylaş
please if some one have it send it to me
i will pay u
hey, i have a site where you can buy it from.
Abubakar Atif - Yanıt Paylaş
here, sorry i am 2 years late lol.. https://www.aliexpress.us/item/325680159...
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 12
Son 30 gün: 44
Her zaman: 2,888
