Giriş
In this guide we will be showing you step-by-step how to replace the button panel. It is a fairly simple process once the front panel and motherboard have been removed.
Neye ihtiyacın var
Using Blue Plastic opening tool pry the top rubber cover, then using the same tool remove the bottom panel
Remove the single screw holding the motherboard to the front panel (Screw : Head PH1, Size .5 cm)
Remove the three screws holding the button board in place (Screw Head PH1, Size 0.5 cm)
You should now be able to remove the button panel from the device.
