Ana içeriğe geç
DKnight MagicBox II Front Panel Assembly Replacement
Neye ihtiyacın var
    1. DKnight MagicBox II Front Panel Assembly Replacement, Front Panel Assembly: adım 1, 2 resimden 1. DKnight MagicBox II Front Panel Assembly Replacement, Front Panel Assembly: adım 1, 2 resimden 2.
      • Using Blue Plastic opening tool pry the top rubber cover, then using the same tool remove the bottom panel
      FixBot'a Sor
      Yorum Ekle
    2. DKnight MagicBox II Front Panel Assembly Replacement: adım 2, 3 resimden 1. DKnight MagicBox II Front Panel Assembly Replacement: adım 2, 3 resimden 2. DKnight MagicBox II Front Panel Assembly Replacement: adım 2, 3 resimden 3.
      • There are four prongs on the grill in the corners, closest to the power button switch. Use the plastic opening tool to release all four prongs from the panel, and then slide the plastic opening tool along the edge of the grill to allow it to easily slide off.
      FixBot'a Sor
      Yorum Ekle
    3. DKnight MagicBox II Front Panel Assembly Replacement: adım 3, 2 resimden 1. DKnight MagicBox II Front Panel Assembly Replacement: adım 3, 2 resimden 2.
      • On the back panel (Opposite to the side containing the two speakers), Use the Philips head PH1 to remove all 7 screws (Screws: Head PH1 , Length 7cm).
      FixBot'a Sor
      Yorum Ekle
    4. DKnight MagicBox II Front Panel Assembly Replacement: adım 4, 2 resimden 1. DKnight MagicBox II Front Panel Assembly Replacement: adım 4, 2 resimden 2.
      • Pull apart the two faces to separate the back panel from the front face plate.
      FixBot'a Sor
      Yorum Ekle
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
Anthony
704 İtibar
3 adet Kılavuz yazıldı
Ekip
USF Tampa, Team 17-1, Blackwell Winter 2016 USF Tampa, Team 17-1, Blackwell Winter 2016 üyesi
USFT-BLACKWELL-W16S17G1
4 Üyeler
6 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 5
Son 30 gün: 21
Her zaman: 1,796
