Ana içeriğe geç
DKnight MagicBox II Motherboard Replacement
Neye ihtiyacın var
  1. DKnight MagicBox II Motherboard  Replacement, Front Panel Assembly: adım 1, 2 resimden 1. DKnight MagicBox II Motherboard  Replacement, Front Panel Assembly: adım 1, 2 resimden 2.
    • Using Blue Plastic opening tool pry the top rubber cover, then using the same tool remove the bottom panel
    FixBot'a Sor
    Yorum Ekle
  2. DKnight MagicBox II Motherboard  Replacement: adım 2, 3 resimden 1. DKnight MagicBox II Motherboard  Replacement: adım 2, 3 resimden 2. DKnight MagicBox II Motherboard  Replacement: adım 2, 3 resimden 3.
    • There are four prongs on the grill in the corners, closest to the power button switch. Use the plastic opening tool to release all four prongs from the panel, and then slide the plastic opening tool along the edge of the grill to allow it to easily slide off.
    FixBot'a Sor
    Yorum Ekle
  3. DKnight MagicBox II Motherboard  Replacement: adım 3, 2 resimden 1. DKnight MagicBox II Motherboard  Replacement: adım 3, 2 resimden 2.
    • On the back panel (Opposite to the side containing the two speakers), Use the Philips head PH1 to remove all 7 screws (Screws: Head PH1 , Length 7cm).
    FixBot'a Sor
    Yorum Ekle
  4. DKnight MagicBox II Motherboard  Replacement: adım 4, 2 resimden 1. DKnight MagicBox II Motherboard  Replacement: adım 4, 2 resimden 2.
    • Pull apart the two faces to separate the back panel from the front face plate.
    FixBot'a Sor
    Yorum Ekle
  5. DKnight MagicBox II Motherboard  Replacement, Motherboard: adım 5, 2 resimden 1. DKnight MagicBox II Motherboard  Replacement, Motherboard: adım 5, 2 resimden 2.
    • Remove the single screw holding the motherboard to the front panel (Screw : Head PH1, Size .5 cm)
    FixBot'a Sor
    Yorum Ekle
  6. DKnight MagicBox II Motherboard  Replacement: adım 6, 1 resimden 1.
    • Using your fingers gently pry the motherboard loose from the black insulant adhesive
    FixBot'a Sor
    Yorum Ekle
  7. DKnight MagicBox II Motherboard  Replacement: adım 7, 1 resimden 1.
    • Disconnect the Button Panel plug (Largest of the Plugs, it can be traced back to the button panel easily)
    FixBot'a Sor
    Yorum Ekle
  8. DKnight MagicBox II Motherboard  Replacement: adım 8, 1 resimden 1.
    Bu adımda kullanılan alet:
    • Use the tweezers to push down on the safety prongs on the plastic switch. Then Disconnect the Power Wire plug by hand (Red medium),
    FixBot'a Sor
    Yorum Ekle
  9. DKnight MagicBox II Motherboard  Replacement: adım 9, 1 resimden 1.
    • Use the tweezers to push down on the two safety prongs on the plastic switch. Then Disconnect the two Speaker plug connections by hand (Two Smaller Plugs)
    FixBot'a Sor
    Yorum Ekle
  10. DKnight MagicBox II Motherboard  Replacement: adım 10, 2 resimden 1. DKnight MagicBox II Motherboard  Replacement: adım 10, 2 resimden 2.
    • The Motherboard is now free from the speaker assembly
    FixBot'a Sor
    Yorum Ekle
Sonuç
10 farklı kişi bu kılavuzu tamamladı.
Anthony
704 İtibar
3 adet Kılavuz yazıldı
Ekip
USF Tampa, Team 17-1, Blackwell Winter 2016 USF Tampa, Team 17-1, Blackwell Winter 2016 üyesi
USFT-BLACKWELL-W16S17G1
4 Üyeler
21Kılavuz Yorumları
Where can I buy a replacement DKnight MagicBox II Motherboard ?
Francis Garvey - Yanıt Paylaş
My Charge Port is not working, do I need to replace the Motherboard or is there a fix for the charge port? Verified that the cable is good. It use to work if I wiggled and applied pressure to one side. Verified port is clean.
Michael Stills - Yanıt Paylaş
Where do you get the replacement motherboard?!
Tracie Yang - Yanıt Paylaş
I did the steps and the power still won't turn on. The blue light will turn on for a blink then nothing
rachelharris0528 - Yanıt Paylaş
mine is doing same thing. DKnight said they wont do anything because i bought it off Ebay and not Amazon.
Peter Tavella - Yanıt Paylaş
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 4
Son 30 gün: 40
Her zaman: 14,379
