Giriş
This guide will help you disassemble your unit and replace your existing damaged LCD.
Neye ihtiyacın var
Pry the casing upward slightly, careful NOT to remove it. Only lift it slightly as shown in the picture.
Using your thumbs gently apply pressure to release the LCD. Both thumbs should be applying even pressure and work your way down to the bottom.
Once LCD is free of casing, remove Rear Case.
Flip the black clamp to the open (up) position using a spudger or other method.
Pull out the flex cable from the clamp using flat needle nose pliers or other method.
Use a Spudger or other tool to release the plastic hold down. Then pry the entire assembly upward releasing it from the socket. Try to keep the part as level as possible while prying up.
Remove the part
Remove 3 silver (0.8mm) screws from the rear metal plate.
Lift up and remove the metal plate
Use the spudger or other tool to flip up the LCD cable clamp.
Use Needle nose pliers or other tool to pull out the cable from the clamp.
Remove the LCD part VYK4P64
Bir başkası bu kılavuzu tamamladı.
