Giriş
Be sure to order the proper buttons. To ensure a proper match, you can order from the manufacturer. Other than that, this replacement will be quick and easy.
Neye ihtiyacın var
You will have to remove the back of the tablet. To do this take the plastic opening tool, and insert it into the side of the tablet and twist.This will pop off the side.
Slowly pull up on the cover until it is completely off.
Buttons will be located on the white back case. Apply small amount of pressure, and they should pop out.
