Ana içeriğe geç
DOPO 10.1 Tablet Dual .3 mega pixel Camera Replacement
Neye ihtiyacın var
    1. DOPO 10.1 Tablet Dual  .3 mega pixel Camera  Replacement, Removing Back of tablet: adım 1, 3 resimden 1. DOPO 10.1 Tablet Dual  .3 mega pixel Camera  Replacement, Removing Back of tablet: adım 1, 3 resimden 2. DOPO 10.1 Tablet Dual  .3 mega pixel Camera  Replacement, Removing Back of tablet: adım 1, 3 resimden 3.
      • You will have to remove the back of the tablet. To do this, take the plastic opening tool, and insert into the side of the tablet and twist. This will pop off the side.
      • Slowly pull up on the cover until it is completely off.
      FixBot'a Sor
      Yorum Ekle
    2. DOPO 10.1 Tablet Dual  .3 mega pixel Camera  Replacement, Relocating obstructions: adım 2, 3 resimden 1. DOPO 10.1 Tablet Dual  .3 mega pixel Camera  Replacement, Relocating obstructions: adım 2, 3 resimden 2. DOPO 10.1 Tablet Dual  .3 mega pixel Camera  Replacement, Relocating obstructions: adım 2, 3 resimden 3.
      • You may notice that the battery is in the way. No worries, it is easy to move. All you will need to do is to gently lift up on the battery with a small constant pressure to release it from the adhesive.
      • Carefully put it off to the side.
      • Once the battery is removed you will see a gray wire. Lightly lift up, and move it out of way.
      FixBot'a Sor
      Yorum Ekle
    3. DOPO 10.1 Tablet Dual  .3 mega pixel Camera  Replacement, Removing Camera from motherboard: adım 3, 3 resimden 1. DOPO 10.1 Tablet Dual  .3 mega pixel Camera  Replacement, Removing Camera from motherboard: adım 3, 3 resimden 2. DOPO 10.1 Tablet Dual  .3 mega pixel Camera  Replacement, Removing Camera from motherboard: adım 3, 3 resimden 3.
      • Locate where the camera is plugged into the motherboard. It should be on the left side of the motherboard just above the center.
      • Once located lift the black lever on the right side of the connector. This will release the camera.
      • Once the lever is lifted, pull out the camera by gently tugging the cameras connector tape.
      FixBot'a Sor
      Yorum Ekle
    4. DOPO 10.1 Tablet Dual  .3 mega pixel Camera  Replacement, Removing Camera from the device: adım 4, 3 resimden 1. DOPO 10.1 Tablet Dual  .3 mega pixel Camera  Replacement, Removing Camera from the device: adım 4, 3 resimden 2. DOPO 10.1 Tablet Dual  .3 mega pixel Camera  Replacement, Removing Camera from the device: adım 4, 3 resimden 3.
      Bu adımda kullanılan alet:
      • Remove yellow tape that is securing the camera to the back cover.
      • Now take tweezers, and gently grab one of the cameras. Once grabbed, begin to twist to remove from device. Do this for both cameras.
      FixBot'a Sor
      Yorum Ekle
Sonuç
For information you can go to http://www.doublepowertech.com/download/...
Kaitlyn Hayes
414 İtibar
4 adet Kılavuz yazıldı
Ekip
USF Tampa, Team 5-2, Brown Winter 2015 USF Tampa, Team 5-2, Brown Winter 2015 üyesi
USFT-BROWN-W15S5G2
4 Üyeler
25 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 3
Son 7 gün: 7
Son 30 gün: 30
Her zaman: 669
