Ana içeriğe geç
DOSS SoundBox Battery Replacement
Neye ihtiyacın var
    1. DOSS SoundBox Battery Replacement, Battery: adım 1, 2 resimden 1. DOSS SoundBox Battery Replacement, Battery: adım 1, 2 resimden 2.
      • Use a JIS #00 screwdriver to remove the four 3/32" screws that attach the base-plate to the speaker enclosure.
      • Use a magnetic mat to prevent the loss of screws.
      FixBot'a Sor
      Yorum Ekle
    2. DOSS SoundBox Battery Replacement: adım 2, 2 resimden 1. DOSS SoundBox Battery Replacement: adım 2, 2 resimden 2.
      • Use a JIS #1 screwdriver to remove the six 3/32" screws marked with a red circle.
      • Remove the two 1/16" screws marked with orange circles using a JIS #000 screwdriver.
      FixBot'a Sor
      Yorum Ekle
    3. DOSS SoundBox Battery Replacement: adım 3, 1 resimden 1.
      • Remove the six 3/32" screws marked with red circles using a JIS #00 screwdriver.
      • Remove the larger 3/32" screw indicated by an orange circle using a JIS #1 screwdriver.
      • Once the screws are removed, gently lift the top (where the touch controls are) off of the speaker.
      FixBot'a Sor
      Yorum Ekle
    4. DOSS SoundBox Battery Replacement: adım 4, 1 resimden 1.
      • De-solder the connections from the battery to the circuit board.
      • If you do not already have a replacement battery, you can purchase one here.
      FixBot'a Sor
      Yorum Ekle
Sonuç
4 farklı kişi bu kılavuzu tamamladı.
5Kılavuz Yorumları
What could be the cause that the box works perfectly on low volume, but as soon as I raise the volume the box shuts down?
Thanks so much for your work here. :)
Milad Etemadi - Yanıt Paylaş
Hi. Thanks for the guide! Can you please let me know how to remove the existing batt, I don’t know if it’s glued or sthing but I can’t take it out, I m stuck there. Tks !!
Philly newrocker - Yanıt Paylaş
Did you manage to get it removed? I don’t know any more details than what this guide offered, but if it is glued in, isopropyl alcohol or some low heat are usually quite helpful. Make sure the battery is drained beforehand, of course, though I doubt it’ll be an issue since you’re trying to replace the battery, most likely because it’s not holding a charge anymore. If you use isopropyl, you can get fairly liberal with it without having to worry about damaging anything so long as you don’t get any on the speakers because the glue used to hold them together can desolve causing separation which would ruin the sound and would need repair.
Thousand Sunny - Yanıt Paylaş
Link for Battery Replacement is broken.
Michael Scibetta - Yanıt Paylaş
I believe this is the new link to replacement battery
Tenergy-37-2200-pcb
Fixer245 - Yanıt Paylaş
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 8
Son 7 gün: 27
Son 30 gün: 119
Her zaman: 15,183
