Ana içeriğe geç
DOSS SoundBox Speaker Replacement
Neye ihtiyacın var
  1. DOSS SoundBox Speaker Replacement, Speaker: adım 1, 2 resimden 1. DOSS SoundBox Speaker Replacement, Speaker: adım 1, 2 resimden 2.
    • Use the JIS #00 screwdriver to remove the 3/32" screws that secure the speaker to the body.
    • Remove the smaller 3/32" screws that secure the left side of the speaker with a JIS #1 screwdriver.
    • The smaller screws are still the same length, but they have smaller screw heads. You can use the same screwdriver for both.
    • Using a Magnetic Mat throughout this process will help prevent losing screws.
  2. DOSS SoundBox Speaker Replacement: adım 2, 2 resimden 1. DOSS SoundBox Speaker Replacement: adım 2, 2 resimden 2.
    • Use the Plastic Opening Tool to gently lift the speaker enough to see the connected wires.
  3. DOSS SoundBox Speaker Replacement: adım 3, 2 resimden 1. DOSS SoundBox Speaker Replacement: adım 3, 2 resimden 2.
    • Use a soldering iron to de-solder the two speaker wires from the speaker itself.
    • The speakers are ready to be removed and replaced.
    • Ensure that the device is turned off when handling bare wire.
    • Soldering iron is very hot.
Sonuç
To reassemble your device, follow instructions in reverse order.
2 farklı kişi bu kılavuzu tamamladı.
1Rehber Yorum
The instructions say: "The speakers are ready to be removed and replaced." But nowhere in this article am I told where to get replacement speakers. Am I just on my own for that? This website has always been so helpful in providing links for such things. :(
Janie Thurman - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 7
Son 30 gün: 46
Her zaman: 3,277
