Ana içeriğe geç
DR.J Professional HI-04 Lamp Replacement
Neye ihtiyacın var
  1. DR.J Professional HI-04 Lamp Replacement, Motherboard: adım 1, 3 resimden 1. DR.J Professional HI-04 Lamp Replacement, Motherboard: adım 1, 3 resimden 2. DR.J Professional HI-04 Lamp Replacement, Motherboard: adım 1, 3 resimden 3.
    • Flip the projector so that the bottom is facing up.
    • Remove the eight 10.0 mm screws with a Phillips #0 screwdriver.
    • The screws are set deep in the holes. Be careful not to drop the screws.
    • Remove the two 20.0 mm screws with a Phillips #0 screwdriver.
  2. DR.J Professional HI-04 Lamp Replacement: adım 2, 3 resimden 1. DR.J Professional HI-04 Lamp Replacement: adım 2, 3 resimden 2. DR.J Professional HI-04 Lamp Replacement: adım 2, 3 resimden 3.
    • Flip the projector so it is upright.
    • Remove the top case of the projector.
    • The top case should come off fairly easily but be gentle while removing it.
    • Don't yank the top case off as there are cables attached to the motherboard and the top case.
  3. DR.J Professional HI-04 Lamp Replacement: adım 3, 2 resimden 1. DR.J Professional HI-04 Lamp Replacement: adım 3, 2 resimden 2.
    • Remove the three pieces of tape securing cables.
    • Keep the tape for reassembly.
  4. DR.J Professional HI-04 Lamp Replacement: adım 4, 2 resimden 1. DR.J Professional HI-04 Lamp Replacement: adım 4, 2 resimden 2.
    • Use a Phillips #0 screwdriver to remove the four 15.0 mm screws from the motherboard.
    • Be sure to not drop the screws in the device as they can be difficult to recover.
  5. DR.J Professional HI-04 Lamp Replacement: adım 5, 2 resimden 1. DR.J Professional HI-04 Lamp Replacement: adım 5, 2 resimden 2.
    • Squeeze the tab against the connector, and pull the connector straight out from the socket.
    • The cable will come out easily so do not pull too hard.
  6. DR.J Professional HI-04 Lamp Replacement: adım 6, 2 resimden 1. DR.J Professional HI-04 Lamp Replacement: adım 6, 2 resimden 2.
    • Lift the motherboard from the device.
    • Use the tip of a spudger or your fingernail to flip up the small locking flap of the ZIF connector.
    • Pull the cable from the connector.
  7. DR.J Professional HI-04 Lamp Replacement: adım 7, 2 resimden 1. DR.J Professional HI-04 Lamp Replacement: adım 7, 2 resimden 2.
    • Set down the motherboard safely.
  8. DR.J Professional HI-04 Lamp Replacement, Lamp: adım 8, 2 resimden 1. DR.J Professional HI-04 Lamp Replacement, Lamp: adım 8, 2 resimden 2.
    • Use a Phillips #0 screwdriver to remove the three 15.0 mm screws from the black cover.
    • The screws are set deep in the holes, so be careful to not drop the screws, as they can be difficult to recover.
  9. DR.J Professional HI-04 Lamp Replacement: adım 9, 2 resimden 1. DR.J Professional HI-04 Lamp Replacement: adım 9, 2 resimden 2.
    • Gently remove the black cover.
  10. DR.J Professional HI-04 Lamp Replacement: adım 10, 2 resimden 1. DR.J Professional HI-04 Lamp Replacement: adım 10, 2 resimden 2.
    • Remove the single piece of black tape.
    • Save the tape for reassembly.
  11. DR.J Professional HI-04 Lamp Replacement: adım 11, 2 resimden 1. DR.J Professional HI-04 Lamp Replacement: adım 11, 2 resimden 2.
    • Use a Phillips #0 screwdriver to remove five 10.0 mm screws.
  12. DR.J Professional HI-04 Lamp Replacement: adım 12, 3 resimden 1. DR.J Professional HI-04 Lamp Replacement: adım 12, 3 resimden 2. DR.J Professional HI-04 Lamp Replacement: adım 12, 3 resimden 3.
  13. DR.J Professional HI-04 Lamp Replacement: adım 13, 2 resimden 1. DR.J Professional HI-04 Lamp Replacement: adım 13, 2 resimden 2.
    • Remove the glass object with the orange ribbon cable connector.
    • Be careful removing object as it is fragile and can easily break.
  14. DR.J Professional HI-04 Lamp Replacement: adım 14, 2 resimden 1. DR.J Professional HI-04 Lamp Replacement: adım 14, 2 resimden 2.
    • Use a Phillips #0 to remove four 10.0 mm screws from the lamp.
  15. DR.J Professional HI-04 Lamp Replacement: adım 15, 2 resimden 1. DR.J Professional HI-04 Lamp Replacement: adım 15, 2 resimden 2.
    • Gently slide the lamp out from the projector case.
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
Baron Dutra
825 İtibar
4 adet Kılavuz yazıldı
Ekip
UMass Dartmouth, Team 1-5, Petersen Fall 2023 UMass Dartmouth, Team 1-5, Petersen Fall 2023 üyesi
UMASSD-PETERSEN-F23S1G5
4 Üyeler
5 adet Kılavuz yazıldı
3Kılavuz Yorumları
Hi Do you know what type of lamp can ne used for replacement please
Chilijon - Yanıt Paylaş
Where can I purchase this lamp to replace in the unit or what is the model number of the lamp so I can search it out?
Dave Haddad - Yanıt Paylaş
MTDM3025-03 is lamp part number
KCrane - Yanıt Paylaş
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 18
Son 30 gün: 60
Her zaman: 1,808
