Ana içeriğe geç
DROCON Ninja Casing Replacement
Neye ihtiyacın var
  1. DROCON Ninja Casing Replacement, Battery: adım 1, 3 resimden 1. DROCON Ninja Casing Replacement, Battery: adım 1, 3 resimden 2. DROCON Ninja Casing Replacement, Battery: adım 1, 3 resimden 3.
    • Make sure the drone is powered off before beginning the battery replacement.
    • To turn the drone off, press and hold the black button on the top of the drone until all lights are off.
    • Firmly grasp the battery tab between your thumb and index finger.
    • Pull the battery away from the drone's body
  2. DROCON Ninja Casing Replacement, Casing: adım 2, 3 resimden 1. DROCON Ninja Casing Replacement, Casing: adım 2, 3 resimden 2. DROCON Ninja Casing Replacement, Casing: adım 2, 3 resimden 3.
    • Using a Phillips #00 Screwdriver remove the eight 4mm screws on the bottom of the drone.
  3. DROCON Ninja Casing Replacement: adım 3, 2 resimden 1. DROCON Ninja Casing Replacement: adım 3, 2 resimden 2.
    • Gently pull white casing away from the black bottom casing
  4. DROCON Ninja Casing Replacement: adım 4, 3 resimden 1. DROCON Ninja Casing Replacement: adım 4, 3 resimden 2. DROCON Ninja Casing Replacement: adım 4, 3 resimden 3.
    • Insert the opening tool under one of the black plastic connector slots that connects the circuit-board to the casing.
    • Gently pull the opening tool toward you to disconnect the circuit-board from the plastic casing.
Sonuç
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 7
Her zaman: 251
