Ana içeriğe geç
DROCON Ninja Motor Replacement
Neye ihtiyacın var
  1. DROCON Ninja Motor Replacement, Battery: adım 1, 3 resimden 1. DROCON Ninja Motor Replacement, Battery: adım 1, 3 resimden 2. DROCON Ninja Motor Replacement, Battery: adım 1, 3 resimden 3.
    • Make sure the drone is powered off before beginning the battery replacement.
    • To turn the drone off, press and hold the black button on the top of the drone until all lights are off.
    • Firmly grasp the battery tab between your thumb and index finger.
    • Pull the battery away from the drone's body
  2. DROCON Ninja Motor Replacement, Casing: adım 2, 3 resimden 1. DROCON Ninja Motor Replacement, Casing: adım 2, 3 resimden 2. DROCON Ninja Motor Replacement, Casing: adım 2, 3 resimden 3.
    • Using a Phillips #00 Screwdriver remove the eight 4mm screws on the bottom of the drone.
  3. DROCON Ninja Motor Replacement: adım 3, 2 resimden 1. DROCON Ninja Motor Replacement: adım 3, 2 resimden 2.
    • Gently pull white casing away from the black bottom casing
  4. DROCON Ninja Motor Replacement: adım 4, 3 resimden 1. DROCON Ninja Motor Replacement: adım 4, 3 resimden 2. DROCON Ninja Motor Replacement: adım 4, 3 resimden 3.
    • Insert the opening tool under one of the black plastic connector slots that connects the circuit-board to the casing.
    • Gently pull the opening tool toward you to disconnect the circuit-board from the plastic casing.
  5. DROCON Ninja Motor Replacement, Motor: adım 5, 2 resimden 1. DROCON Ninja Motor Replacement, Motor: adım 5, 2 resimden 2.
    • Firmly grasp the blade guard from the bottom of the drone
    • Pull the blade guard straight down away from motor.
  6. DROCON Ninja Motor Replacement: adım 6, 3 resimden 1. DROCON Ninja Motor Replacement: adım 6, 3 resimden 2. DROCON Ninja Motor Replacement: adım 6, 3 resimden 3.
    • Grasp the center of the propeller that needs to be replaced.
    • Pull the propeller directly up and away from the motor.
  7. DROCON Ninja Motor Replacement: adım 7, 3 resimden 1. DROCON Ninja Motor Replacement: adım 7, 3 resimden 2. DROCON Ninja Motor Replacement: adım 7, 3 resimden 3.
    • Use a Phillips #00 screwdriver to remove the two 5mm screws connecting the motor arm to the drone's body.
    • Use your fingers to gently pull the white plastic disc out of the motor arm.
  8. DROCON Ninja Motor Replacement: adım 8, 3 resimden 1. DROCON Ninja Motor Replacement: adım 8, 3 resimden 2. DROCON Ninja Motor Replacement: adım 8, 3 resimden 3.
    • Grasp the motor arm and pull up and away from the drone's body.
  9. DROCON Ninja Motor Replacement: adım 9, 3 resimden 1. DROCON Ninja Motor Replacement: adım 9, 3 resimden 2. DROCON Ninja Motor Replacement: adım 9, 3 resimden 3.
    • Use a Phillips #00 screwdriver to remove the three 4mm screws on the plate of the motor arm.
    • Using your fingers, pull apart the top and bottom pieces of the casing.
  10. DROCON Ninja Motor Replacement: adım 10, 3 resimden 1. DROCON Ninja Motor Replacement: adım 10, 3 resimden 2. DROCON Ninja Motor Replacement: adım 10, 3 resimden 3.
    • Use the opening tool to remove the small circuit board from the motor arm.
  11. DROCON Ninja Motor Replacement: adım 11, 3 resimden 1. DROCON Ninja Motor Replacement: adım 11, 3 resimden 2. DROCON Ninja Motor Replacement: adım 11, 3 resimden 3.
    • Use a pair of pliers to remove the motor by pulling up and away from the propeller arm.
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
1Rehber Yorum
I’ve got the motor out. Thank you! Now to find a suitable replacement. Do you know the specs of the motor or a source for a working one?
Tinkerer - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 4
Son 30 gün: 12
Her zaman: 863
