Ana içeriğe geç
DROCON Ninja Motor Replacement
Neye ihtiyacın var
  1. DROCON Ninja Motor Replacement, Battery: adım 1, 3 resimden 1. DROCON Ninja Motor Replacement, Battery: adım 1, 3 resimden 2. DROCON Ninja Motor Replacement, Battery: adım 1, 3 resimden 3.
    • Make sure the drone is powered off before beginning the battery replacement.
    • To turn the drone off, press and hold the black button on the top of the drone until all lights are off.
    • Firmly grasp the battery tab between your thumb and index finger.
    • Pull the battery away from the drone's body
    Great work with the action shot and writing clearly here, but notice that you’re taking the shots as if you’re watching, not from first-person perspective.
    Alex Watkins - Yanıt
  2. DROCON Ninja Motor Replacement, Casing: adım 2, 3 resimden 1. DROCON Ninja Motor Replacement, Casing: adım 2, 3 resimden 2. DROCON Ninja Motor Replacement, Casing: adım 2, 3 resimden 3.
    • Using a Phillips #00 Screwdriver remove the eight 4mm screws on the bottom of the drone.
    Add screw length measurements to all guides.
    Also, be sure to use a red bullet to coincide with red markup.
  3. DROCON Ninja Motor Replacement: adım 3, 2 resimden 1. DROCON Ninja Motor Replacement: adım 3, 2 resimden 2.
    • Gently pull white casing away from the black bottom casing
    It looks like you’re kind of wedging your fingers between the two pieces. Is that correct? If so, add that detail here. If it’s just really gently pulling, then keep as is.
  4. DROCON Ninja Motor Replacement: adım 4, 3 resimden 1. DROCON Ninja Motor Replacement: adım 4, 3 resimden 2. DROCON Ninja Motor Replacement: adım 4, 3 resimden 3.
    • Insert the opening tool under one of the black plastic connector slots that connects the circuit-board to the casing.
    • Gently pull the opening tool toward you to disconnect the circuit-board from the plastic casing.
    What is the red markup for? Note that circular markup is only for screws. Also, for the wires, how can they tell if they are in the appropriate slots?
  5. DROCON Ninja Motor Replacement, Motor: adım 5, 2 resimden 1. DROCON Ninja Motor Replacement, Motor: adım 5, 2 resimden 2.
    • Firmly grasp the blade guard from the bottom of the drone
    • Pull the blade guard straight down away from motor.
  6. DROCON Ninja Motor Replacement: adım 6, 3 resimden 1. DROCON Ninja Motor Replacement: adım 6, 3 resimden 2. DROCON Ninja Motor Replacement: adım 6, 3 resimden 3.
    • Grasp the center of the propeller that needs to be replaced.
    • Pull the propeller directly up and away from the motor.
  7. DROCON Ninja Motor Replacement: adım 7, 3 resimden 1. DROCON Ninja Motor Replacement: adım 7, 3 resimden 2. DROCON Ninja Motor Replacement: adım 7, 3 resimden 3.
    • Use a Phillips #00 screwdriver to remove the two 5mm screws connecting the motor arm to the drone's body.
    • Use your fingers to gently pull the white plastic disc out of the motor arm.
  8. DROCON Ninja Motor Replacement: adım 8, 3 resimden 1. DROCON Ninja Motor Replacement: adım 8, 3 resimden 2. DROCON Ninja Motor Replacement: adım 8, 3 resimden 3.
    • Grasp the motor arm and pull up and away from the drone's body.
  9. DROCON Ninja Motor Replacement: adım 9, 3 resimden 1. DROCON Ninja Motor Replacement: adım 9, 3 resimden 2. DROCON Ninja Motor Replacement: adım 9, 3 resimden 3.
    • Use a Phillips #00 screwdriver to remove the three 4mm screws on the plate of the motor arm.
    • Using your fingers, pull apart the top and bottom pieces of the casing.
    Why is this first step italicized? Make sure to use appropriately colored bullets. How should I separate the motor arm casing? Try to be more specific in the second bullet.
  10. DROCON Ninja Motor Replacement: adım 10, 3 resimden 1. DROCON Ninja Motor Replacement: adım 10, 3 resimden 2. DROCON Ninja Motor Replacement: adım 10, 3 resimden 3.
    • Use the opening tool to remove the small circuit board from the motor arm.
    Proofread this step carefully. Between the picture missing a step and the text, I’m having trouble understanding what’s going on here.
  11. DROCON Ninja Motor Replacement: adım 11, 3 resimden 1. DROCON Ninja Motor Replacement: adım 11, 3 resimden 2. DROCON Ninja Motor Replacement: adım 11, 3 resimden 3.
    • Use a pair of pliers to remove the motor by pulling up and away from the propeller arm.
    Proofreading issue here.
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
Bir Yorum
I’ve got the motor out. Thank you! Now to find a suitable replacement. Do you know the specs of the motor or a source for a working one?
Tinkerer - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 13
Her zaman: 717
