Bu sürüm, hatalı düzenlemeler içerebilir. En son doğrulanmış bellek kopyası dönün.
Neye ihtiyacın var
Bu adım çevrilmemiş. Çevrilmesine yardım edin
To turn the drone off, press and hold the black button on the top of the drone until all lights are off.
Firmly grasp the battery tab between your thumb and index finger.
Pull the battery away from the drone's body
Using a Phillips #00 Screwdriver remove the eight 4mm screws on the bottom of the drone.
Gently pull white casing away from the black bottom casing
Insert the opening tool under one of the black plastic connector slots that connects the circuit-board to the casing.
Gently pull the opening tool toward you to disconnect the circuit-board from the plastic casing.
Firmly grasp the blade guard from the bottom of the drone
Pull the blade guard straight down away from motor.
Grasp the center of the propeller that needs to be replaced.
Pull the propeller directly up and away from the motor.
Use a Phillips #00 screwdriver to remove the two 5mm screws connecting the motor arm to the drone's body.
Use your fingers to gently pull the white plastic disc out of the motor arm.
Grasp the motor arm and pull up and away from the drone's body.
Use a Phillips #00 screwdriver to remove the three 4mm screws on the plate of the motor arm.
Using your fingers, pull apart the top and bottom pieces of the casing.
Use the opening tool to remove the small circuit board from the motor arm.
Use a pair of pliers to remove the motor by pulling up and away from the propeller arm.
2 farklı kişi bu kılavuzu tamamladı.
