Ana içeriğe geç
DWFP55130 Regulator spring Replacement
Neye ihtiyacın var
  1. DWFP55130 Regulator spring Replacement, Remove regulator knob: adım 1, 1 resimden 1.
    • Unscrew and remove the black plastic regulator knob. While unscrewing, it will reach a stop and will keep like cannot unscrew further. Just break through the stop and unscrew to completely remove
  2. DWFP55130 Regulator spring Replacement, Remove plunger actuator: adım 2, 1 resimden 1.
    • Use needle nose pliers to remove the plunger.
  3. DWFP55130 Regulator spring Replacement, Use Philips #3 (large) screw driver: adım 3, 1 resimden 1.
    • Very gently unscrew the valve with a Philips #3 screwdriver. Take care not to destroy the plastic part
  4. DWFP55130 Regulator spring Replacement, Remove plastic valve: adım 4, 1 resimden 1.
    • Use needle nose pliers to pull plastic valve assembly out
  5. DWFP55130 Regulator spring Replacement, Replace broken screw: adım 5, 1 resimden 1.
    • Replace screw if broken. Photo is not of the original spring. The original spring had corroded and broken into 50 pieces. The spring doesn’t have to be a perfect fit, just has to hold the part in place. The original spring was approx 6mm wide, 20mm tall and 0.5mm thickness wire.
  6. DWFP55130 Regulator spring Replacement, Reassemble: adım 6, 1 resimden 1.
    • Carry out steps in reverse to reassemble compressor and you’re done
Sonuç
Imran Latif
158 İtibar
1 Kılavuz yazıldı
5Kılavuz Yorumları
do you know the replacement part numbers just in case?
myke - Yanıt
The replacement parts are not listed in the manual and not available for sale. Hence this workaround.
Imran Latif - Yanıt
what type of spring did you replace it with?
Gaeilge 6 - Yanıt
Random screw I found from a 3D printer part. Size and shape were both different than the original spring. As long as the dimension are similar to 6mm wide and 20mm tall, it would work. The spring I used was not 6mm by 2omm but close enough that it worked.
Imran Latif - Yanıt
Replaced and still leaks. Tried replacing o ring and still leaks.
Rollin Blanton - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 6
Son 30 gün: 57
Her zaman: 881
