Ana içeriğe geç
DYMO LabelPOINT 100 Cutting Blade Replacement
Neye ihtiyacın var
  1. DYMO LabelPOINT 100 Cutting Blade Replacement, Rear Panel: adım 1, 3 resimden 1. DYMO LabelPOINT 100 Cutting Blade Replacement, Rear Panel: adım 1, 3 resimden 2. DYMO LabelPOINT 100 Cutting Blade Replacement, Rear Panel: adım 1, 3 resimden 3.
    • Slide the panel release button.
    • Lift the panel.
    FixBot'a Sor
    Yorum Ekle
  2. DYMO LabelPOINT 100 Cutting Blade Replacement, Remove Label Tape Cassette: adım 2, 2 resimden 1. DYMO LabelPOINT 100 Cutting Blade Replacement, Remove Label Tape Cassette: adım 2, 2 resimden 2.
    • Firmly press the cartridge release button with your finger.
    • You may need to hold the cassette and/or entire device still while pressing the button.
    • Lift the label tape cassette out of the device.
    FixBot'a Sor
    Yorum Ekle
  3. DYMO LabelPOINT 100 Cutting Blade Replacement, Blade Disassembly: adım 3, 3 resimden 1. DYMO LabelPOINT 100 Cutting Blade Replacement, Blade Disassembly: adım 3, 3 resimden 2. DYMO LabelPOINT 100 Cutting Blade Replacement, Blade Disassembly: adım 3, 3 resimden 3.
    • Use Phillips #00 Screwdriver to disengage cutter from device
    • Remove cutter
    FixBot'a Sor
    Yorum Ekle
  4. DYMO LabelPOINT 100 Cutting Blade Replacement, Remove Blade: adım 4, 3 resimden 1. DYMO LabelPOINT 100 Cutting Blade Replacement, Remove Blade: adım 4, 3 resimden 2. DYMO LabelPOINT 100 Cutting Blade Replacement, Remove Blade: adım 4, 3 resimden 3.
    • Use Phillips #00 screw to unscrew blade from blade cutter
    • Carefully remove blade. The blade is sharp and can be dangerous if not handled properly.
    • Replace blade
    FixBot'a Sor
    Yorum Ekle
Sonuç
Bir başkası bu kılavuzu tamamladı.
Dustin Holifer
207 İtibar
2 adet Kılavuz yazıldı
Ekip
USF Tampa, Team 5-2, Mcgee Fall 2014 USF Tampa, Team 5-2, Mcgee Fall 2014 üyesi
USFT-MCGEE-F14S5G2
4 Üyeler
6 adet Kılavuz yazıldı
1Rehber Yorum
dangerous? Really :) haha anyway nice review.
speedy - Yanıt Paylaş
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 6
Son 30 gün: 31
Her zaman: 2,976
