Ana içeriğe geç
Daewoo KOC-9U0T Lightbulb Replacement
Neye ihtiyacın var
  1. Daewoo KOC-9U0T Lightbulb Replacement, Lightbulb: adım 1, 1 resimden 1.
    • Never attempt to change the bulb in a microwave while the microwave is still plugged in or while power is being supplied.
    • Unplug the microwave from any wall outlets or power sources.
  2. Daewoo KOC-9U0T Lightbulb Replacement: adım 2, 1 resimden 1.
    • Examine your microwave to find the vent on the back of the microwave.
    • On other microwaves, there will be a vent located either in the front, side or bottom of the machine, depending on make, model, and mounting.
  3. Daewoo KOC-9U0T Lightbulb Replacement: adım 3, 1 resimden 1.
    • Remove the four 20 x 3" screws on the rear side of the microwave using a Phillips #0 screwdriver.
  4. Daewoo KOC-9U0T Lightbulb Replacement: adım 4, 1 resimden 1.
    • Lift off the service panel of the microwave and set it aside.
    • Do not attempt to change the light bulb from within the microwave's interior; always remove the vent panel and change the light bulb from within.
  5. Daewoo KOC-9U0T Lightbulb Replacement: adım 5, 1 resimden 1.
    • Locate the box that the halogen light is kept in.
    • Search for the light box that contains the bulb.
  6. Daewoo KOC-9U0T Lightbulb Replacement: adım 6, 1 resimden 1.
    • Remove the screws that hold the lightbox in place with a Phillips #0 screwdriver.
  7. Daewoo KOC-9U0T Lightbulb Replacement: adım 7, 1 resimden 1.
    • Unscrew and remove the light bulb from the socket on the lightbox.
    • Replace it with a new light bulb.
    • Screw the lightbox back into place on the frame of the microwave.
  8. Daewoo KOC-9U0T Lightbulb Replacement: adım 8, 1 resimden 1.
    • Replace the service panel and tighten down the screws.
    • Make sure you tighten the screws hard enough because if it the cover of the microwave is loose, then the radiations can harm your body.
  9. Daewoo KOC-9U0T Lightbulb Replacement: adım 9, 1 resimden 1.
    • Plug the microwave back in or reset the breaker.
    • You’re ready to see if your microwave has been repaired.
  10. Daewoo KOC-9U0T Lightbulb Replacement: adım 10, 1 resimden 1.
    • Open the microwave's door to test the new light bulb: If you’ve replaced the bulb correctly and the new bulb is working properly, then the light should go back on when you reopen the microwave’s door!
Sonuç
3 farklı kişi bu kılavuzu tamamladı.
1Rehber Yorum
This is'nt the KOC-9U0T.... i have the KOC-9U0T model and it looks nothing like the pictures in this guide....
explainet - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 10
Son 30 gün: 80
Her zaman: 2,774
