Ana içeriğe geç
De' Longhi CTOV 2103- AZ
Neye ihtiyacın var
  1. De' Longhi CTOV 2103- AZ, Pull the lever: adım 1, 3 resimden 1. De' Longhi CTOV 2103- AZ, Pull the lever: adım 1, 3 resimden 2. De' Longhi CTOV 2103- AZ, Pull the lever: adım 1, 3 resimden 3.
    • First unplug the cable. ...Pull off the lever, it is snapped in.
    • Pull out the drawer.
    • Now clean it with a vacuum.
    • On the underside are 4 screws Torx 10 resistant visible - in each corner one.
  2. De' Longhi CTOV 2103- AZ, Screw: adım 2, 2 resimden 1. De' Longhi CTOV 2103- AZ, Screw: adım 2, 2 resimden 2.
    • Detail of the screw
  3. De' Longhi CTOV 2103- AZ, Housing chrome plastic ring: adım 3, 3 resimden 1. De' Longhi CTOV 2103- AZ, Housing chrome plastic ring: adım 3, 3 resimden 2. De' Longhi CTOV 2103- AZ, Housing chrome plastic ring: adım 3, 3 resimden 3.
    • here you have two pictures of the housing and the chrome plastic frame.
  4. De' Longhi CTOV 2103- AZ, Lever: adım 4, 2 resimden 1. De' Longhi CTOV 2103- AZ, Lever: adım 4, 2 resimden 2.
    • Here you have details of the lever and how it is snapped in the mechanic.
    • This shows you how to unlock it when you dismantle the housing. Good luck. ;)
  5. De' Longhi CTOV 2103- AZ, Tempeaturesensor: adım 5, 2 resimden 1. De' Longhi CTOV 2103- AZ, Tempeaturesensor: adım 5, 2 resimden 2.
    • Detail of the Sensor: It is the little black pearl at the black hoses which is strapped to the white hose.
  6. De' Longhi CTOV 2103- AZ: adım 6, 3 resimden 1. De' Longhi CTOV 2103- AZ: adım 6, 3 resimden 2. De' Longhi CTOV 2103- AZ: adım 6, 3 resimden 3.
    • The connector from the main platine to the switch platine.
  7. De' Longhi CTOV 2103- AZ: adım 7, 3 resimden 1. De' Longhi CTOV 2103- AZ: adım 7, 3 resimden 2. De' Longhi CTOV 2103- AZ: adım 7, 3 resimden 3.
    • Details of the plug and the bottom part after disassembly.
    • Where to find the plug for the yellow ground wire i show you in the next step. :)
  8. De' Longhi CTOV 2103- AZ: adım 8, 2 resimden 1. De' Longhi CTOV 2103- AZ: adım 8, 2 resimden 2.
    • here you can see where the yellow cable belongs to.
  9. De' Longhi CTOV 2103- AZ, Reassembly: adım 9, 3 resimden 1. De' Longhi CTOV 2103- AZ, Reassembly: adım 9, 3 resimden 2. De' Longhi CTOV 2103- AZ, Reassembly: adım 9, 3 resimden 3.
    • Reassembly: Putt all cables at the right places, don't forget the yellow cable at the housing !!!
    • Look at the picture how to fit in the metal notch in the right place !
  10. De' Longhi CTOV 2103- AZ: adım 10, 3 resimden 1. De' Longhi CTOV 2103- AZ: adım 10, 3 resimden 2. De' Longhi CTOV 2103- AZ: adım 10, 3 resimden 3.
    • Here the notch is in the right place.
    • Do NOT forget to make an insulation test. Check the wiring with a multimeter.
    • Made in China.
    • Hope it was fun and may the pictures help you. Greets. :)
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
Schwarzstein
2.813 İtibar
13 adet Kılavuz yazıldı
2 Yorum
The lever broke on my toaster. And it's difficult to glue it.
skan - Yanıt
My daughter toasted a piece of bread but the bread burned and caught fire. I've opened the toaster, and see no fire-damage. Although, it is impossible to toast because the lever won't stay down.
Dieter Troubleyn - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 10
Son 30 gün: 38
Her zaman: 2,466
