Giriş
I show how it is opened.
Neye ihtiyacın var
First unplug the cable. ...Pull off the lever, it is snapped in.
Pull out the drawer.
Now clean it with a vacuum.
On the underside are 4 screws Torx 10 resistant visible - in each corner one.
here you have two pictures of the housing and the chrome plastic frame.
Here you have details of the lever and how it is snapped in the mechanic.
This shows you how to unlock it when you dismantle the housing. Good luck. ;)
Detail of the Sensor: It is the little black pearl at the black hoses which is strapped to the white hose.
Reassembly: Putt all cables at the right places, don't forget the yellow cable at the housing !!!
Look at the picture how to fit in the metal notch in the right place !
2 farklı kişi bu kılavuzu tamamladı.
2Kılavuz Yorumları
My daughter toasted a piece of bread but the bread burned and caught fire. I've opened the toaster, and see no fire-damage. Although, it is impossible to toast because the lever won't stay down.
