Giriş
Using the test mode you can proof the function of the most important components.
Pull the plug. Switch on rear side is in position "On".
Press and hold both keys for "one cup" and "steam".
Reconnect the plug.
LEDs light up. When they are off again, the machine is in test mode. Release the two keys.
Press the key "one cup". The motor should drive down. If it reaches the lower end position the correspondending LED will light up.
Press the key two cups". The motor should drive upwards. If it reaches the upper end position the correspondending LED will light up.
Press the "steam" key. The pump should be activated. If the steam wand is opened the water should flow.
Press the "Rinse" key. One LED should light up and the heater should be activated. If it reaches the end temperature, the LED goes out.
Bir başkası bu kılavuzu tamamladı.
Bu çevirmenlere özel teşekkürler:
100%
Bu çevirmenler dünyayı onarmamıza yardım ediyor! Katkıda bulunmak ister misiniz?
Çeviriye Başlayın ›
