Giriş
Use this guide to disassemble your drill for cleaning, troubleshooting, or other maintenance.
Neye ihtiyacın var
Remove the seven T20 screws.
Use the T-handle configuration of the screwdriver for the necessary force to loosen the screws.
Place the motor back into the bottom half of the clamshell case.
Make sure the three ball bearings are aligned with their receptors. Slightly adjusting the armature inside the field may be necessary.
Plug it in and see if it works more reliably.
5 farklı kişi bu kılavuzu tamamladı.
