Ana içeriğe geç
DeWALT Hammer Drill DW511 Brush Replacement
Neye ihtiyacın var
  1. DeWALT Hammer Drill DW511 Brush Replacement, Back Cover: adım 1, 3 resimden 1. DeWALT Hammer Drill DW511 Brush Replacement, Back Cover: adım 1, 3 resimden 2. DeWALT Hammer Drill DW511 Brush Replacement, Back Cover: adım 1, 3 resimden 3.
    • Remove three 19 mm T20 Torx screws from the back of the drill.
  2. DeWALT Hammer Drill DW511 Brush Replacement: adım 2, 3 resimden 1. DeWALT Hammer Drill DW511 Brush Replacement: adım 2, 3 resimden 2. DeWALT Hammer Drill DW511 Brush Replacement: adım 2, 3 resimden 3.
    • Place an opening tool in the groove line of the handle and pop the back loose.
    • Grab the drill with two hands and pull the cover off.
  3. DeWALT Hammer Drill DW511 Brush Replacement, Power Cord: adım 3, 2 resimden 1. DeWALT Hammer Drill DW511 Brush Replacement, Power Cord: adım 3, 2 resimden 2.
    • Firmly grab the body of the trigger.
    • Slowly pull the trigger until the entire body is out and only attached by wires.
  4. DeWALT Hammer Drill DW511 Brush Replacement: adım 4, 3 resimden 1. DeWALT Hammer Drill DW511 Brush Replacement: adım 4, 3 resimden 2. DeWALT Hammer Drill DW511 Brush Replacement: adım 4, 3 resimden 3.
    Bu adımda kullanılan alet:
    Satın Al
    • With sharp point tweezers, push the little metal flap up in the hole holding the wire.
    • Clamp the wire with blunt tweezers, and slowly pull the wire out.
  5. DeWALT Hammer Drill DW511 Brush Replacement: adım 5, 3 resimden 1. DeWALT Hammer Drill DW511 Brush Replacement: adım 5, 3 resimden 2. DeWALT Hammer Drill DW511 Brush Replacement: adım 5, 3 resimden 3.
    • With a pair of blunt nose tweezers, grab the white wire.
    • Carefully wiggle the wire loose.
    • Pull the wire slowly until it comes out.
  6. DeWALT Hammer Drill DW511 Brush Replacement: adım 6, 1 resimden 1.
    • With both wires free, the power cord is free from the trigger body.
  7. DeWALT Hammer Drill DW511 Brush Replacement, Brushes: adım 7, 3 resimden 1. DeWALT Hammer Drill DW511 Brush Replacement, Brushes: adım 7, 3 resimden 2. DeWALT Hammer Drill DW511 Brush Replacement, Brushes: adım 7, 3 resimden 3.
    • Use an opening tool to lift up the spring holding down the brush.
    • Remove the brush from its holding.
  8. DeWALT Hammer Drill DW511 Brush Replacement: adım 8, 2 resimden 1. DeWALT Hammer Drill DW511 Brush Replacement: adım 8, 2 resimden 2.
    Satın Al
    • With a pair of blunt nose tweezers, grab the red wire.
Sonuç
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 10
Her zaman: 1,151
