Giriş
Welcome to the Dewalt Hammer Drill DW511 brush spring replacement guide. The brush springs are an important component that hold the brushes in place so the brushes are not loose. Having strong springs is important because once springs go loose and the brushes do not work properly, the drill will overheat.
Caution: the springs are made of a small thin metal that is easy to break and easy to lose.
Neye ihtiyacın var
Firmly grab the body of the trigger.
Slowly pull the trigger until the entire body is out and only attached by wires.
With broad-tipped tweezers, grab the bottom flap of the metal spring.
Pull the flap up and proceed to pull off the spring.
Bir başkası bu kılavuzu tamamladı.
