Ana içeriğe geç
DeWALT Hammer Drill DW511 Chuck Replacement
Neye ihtiyacın var
  1. DeWALT Hammer Drill DW511 Chuck Replacement, Lever Assembly: adım 1, 3 resimden 1. DeWALT Hammer Drill DW511 Chuck Replacement, Lever Assembly: adım 1, 3 resimden 2. DeWALT Hammer Drill DW511 Chuck Replacement, Lever Assembly: adım 1, 3 resimden 3.
    • Remove two 45 mm T20 Torx screws.
    • Remove one 30 mm T20 Torx screw.
  2. DeWALT Hammer Drill DW511 Chuck Replacement: adım 2, 1 resimden 1.
    • Pull off the top case and set it aside.
  3. DeWALT Hammer Drill DW511 Chuck Replacement: adım 3, 3 resimden 1. DeWALT Hammer Drill DW511 Chuck Replacement: adım 3, 3 resimden 2. DeWALT Hammer Drill DW511 Chuck Replacement: adım 3, 3 resimden 3.
    • Grab the gear case cover and gently pull it out just enough to where it exposes the lever assembly.
    • It is important that the brushes are removed before you do this step or you may damage your brushes.
    • The lever assembly can now be lifted out.
  4. DeWALT Hammer Drill DW511 Chuck Replacement: adım 4, 1 resimden 1.
    • With the old lever assembly removed you can now replace it with a new one.
  5. DeWALT Hammer Drill DW511 Chuck Replacement, Chuck: adım 5, 3 resimden 1. DeWALT Hammer Drill DW511 Chuck Replacement, Chuck: adım 5, 3 resimden 2. DeWALT Hammer Drill DW511 Chuck Replacement, Chuck: adım 5, 3 resimden 3.
    • Gently separate the chuck and plastic housing from the hammer drill body.
    • The removal of the screw from the chuck to separate the plastic housing requires hand strength and specialized tools.
    • The plastic housing is prone to damage if excessive force is applied during the replacement.
Sonuç
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 4
Son 30 gün: 20
Her zaman: 706
