Ana içeriğe geç
DeWalt D26451 Power Switch Replacement
Neye ihtiyacın var
  1. DeWalt D26451 Power Switch Replacement, Power Cord: adım 1, 1 resimden 1.
    • Please wear safety glasses while completing this guide.
    • Remove screws (3) from cap by using the T20 torx attachment and unscrewing in a leftward motion.
  2. DeWalt D26451 Power Switch Replacement: adım 2, 1 resimden 1.
    • Gently pry the cap off using your fingers or spudger tool.
  3. DeWalt D26451 Power Switch Replacement: adım 3, 1 resimden 1.
    • Once cap is off, expose and locate the power cord mounting bracket and remove the 2 screws holding the wire down by using the T15 torx attachment. Once the cord is loose, pull the connectors out
  4. DeWalt D26451 Power Switch Replacement: adım 4, 1 resimden 1.
    • Loosen the white and black wire terminals
  5. DeWalt D26451 Power Switch Replacement: adım 5, 1 resimden 1.
    • Insert new power cord terminals and tighten down
    • Do not over-tighten
  6. DeWalt D26451 Power Switch Replacement, Power Switch: adım 6, 1 resimden 1.
    • Remove screws (3) from the cap using a T20 torx attachment by unscrewing in a leftward motion
  7. DeWalt D26451 Power Switch Replacement: adım 7, 1 resimden 1.
  8. DeWalt D26451 Power Switch Replacement: adım 8, 1 resimden 1.
    • Once the cap is removed, the switch and connectors should be exposed
  9. DeWalt D26451 Power Switch Replacement: adım 9, 1 resimden 1.
    • Remove both connectors from the switch
Sonuç
Bir başkası bu kılavuzu tamamladı.
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 2
Son 30 gün: 19
Her zaman: 1,286
