Ana içeriğe geç
DeWalt D28110 Brush and Spring Replacement
Neye ihtiyacın var
  1. DeWalt D28110 Brush and Spring Replacement, Disassembling DeWalt D28110 Back Panel Disassembly: adım 1, 1 resimden 1.
    • Using the T-15 screwdriver, remove the four 22-mm torx screws holding the back panel in place.
    • Unplug the grinder before any disassembly.
  2. DeWalt D28110 Brush and Spring Replacement: adım 2, 1 resimden 1.
    • Use the edge of the spudger to loosen and remove the back panel.
  3. DeWalt D28110 Brush and Spring Replacement: adım 3, 1 resimden 1.
    • Remove the single 20-mm torx screw holding the rear panel in place.
  4. DeWalt D28110 Brush and Spring Replacement: adım 4, 1 resimden 1.
    • Pull back the rear side of the back panel.
  5. DeWalt D28110 Brush and Spring Replacement, Brush and Spring: adım 5, 2 resimden 1. DeWalt D28110 Brush and Spring Replacement, Brush and Spring: adım 5, 2 resimden 2.
    • Gently pull to disconnect brush connector.
  6. DeWalt D28110 Brush and Spring Replacement: adım 6, 2 resimden 1. DeWalt D28110 Brush and Spring Replacement: adım 6, 2 resimden 2.
    • Use the edge of the spudger to slide the spring off its post.
  7. DeWalt D28110 Brush and Spring Replacement: adım 7, 1 resimden 1.
    Bu adımda kullanılan alet:
    Satın Al
    • Use tweezers to gently remove the brush and cable.
Sonuç
Kean Wee
495 İtibar
4 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 18-6, Maness Winter 2015 Cal Poly, Team 18-6, Maness Winter 2015 üyesi
CPSU-MANESS-W15S18G6
5 Üyeler
7 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 20
Her zaman: 2,264
