Ana içeriğe geç
DeWalt D28110 Power Cord Replacement
Neye ihtiyacın var
  1. DeWalt D28110 Power Cord Replacement, Disassembling DeWalt D28110 Back Panel Disassembly: adım 1, 1 resimden 1.
    • Using the T-15 screwdriver, remove the four 22-mm torx screws holding the back panel in place.
    • Unplug the grinder before any disassembly.
  2. DeWalt D28110 Power Cord Replacement: adım 2, 1 resimden 1.
    • Use the edge of the spudger to loosen and remove the back panel.
  3. DeWalt D28110 Power Cord Replacement: adım 3, 1 resimden 1.
    • Remove the single 20-mm torx screw holding the rear panel in place.
  4. DeWalt D28110 Power Cord Replacement: adım 4, 1 resimden 1.
    • Pull back the rear side of the back panel.
  5. DeWalt D28110 Power Cord Replacement, Power Cord: adım 5, 3 resimden 1. DeWalt D28110 Power Cord Replacement, Power Cord: adım 5, 3 resimden 2. DeWalt D28110 Power Cord Replacement, Power Cord: adım 5, 3 resimden 3.
    • Locate the red switch box.
    • Using the J-10 screwdriver, unscrew the screws and detach the wires.
    • Be sure to remember under which screw the "ground" wire (black) goes.
  6. DeWalt D28110 Power Cord Replacement: adım 6, 1 resimden 1.
    • Unthread the two wires from the power cord clamp.
Sonuç
Andrew
270 İtibar
1 Kılavuz yazıldı
Ekip
Cal Poly, Team 18-6, Maness Winter 2015 Cal Poly, Team 18-6, Maness Winter 2015 üyesi
CPSU-MANESS-W15S18G6
5 Üyeler
7 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 4
Son 30 gün: 22
Her zaman: 1,774
