Ana içeriğe geç
DeWalt D28110 Power Switch Replacement
Neye ihtiyacın var
  1. DeWalt D28110 Power Switch Replacement, Disassembling DeWalt D28110 Gear Case: adım 1, 1 resimden 1.
    • Using the T-15 screwdriver, remove the four 22-mm torx screws on the gear case.
    • Unplug the grinder before any disassembly.
  2. DeWalt D28110 Power Switch Replacement: adım 2, 2 resimden 1. DeWalt D28110 Power Switch Replacement: adım 2, 2 resimden 2.
    • Pull out the gear case.
  3. DeWalt D28110 Power Switch Replacement, Disassembling DeWalt D28110 Back Panel Disassembly: adım 3, 1 resimden 1.
    • Using the T-15 screwdriver, remove the four 22-mm torx screws holding the back panel in place.
  4. DeWalt D28110 Power Switch Replacement: adım 4, 1 resimden 1.
    • Use the edge of the spudger to loosen and remove the back panel.
  5. DeWalt D28110 Power Switch Replacement: adım 5, 1 resimden 1.
    • Remove the single 20-mm torx screw holding the rear panel in place.
  6. DeWalt D28110 Power Switch Replacement: adım 6, 1 resimden 1.
    • Pull back the rear side of the back panel.
  7. DeWalt D28110 Power Switch Replacement, Power Switch: adım 7, 3 resimden 1. DeWalt D28110 Power Switch Replacement, Power Switch: adım 7, 3 resimden 2. DeWalt D28110 Power Switch Replacement, Power Switch: adım 7, 3 resimden 3.
    • There is an inner plastic guard behind the motor shaft.
    • Unscrew the four screws at each corner.
    • The guard should pull out with a good firm tug.
  8. DeWalt D28110 Power Switch Replacement: adım 8, 3 resimden 1. DeWalt D28110 Power Switch Replacement: adım 8, 3 resimden 2. DeWalt D28110 Power Switch Replacement: adım 8, 3 resimden 3.
    • Just behind the inner guard is the button slide.
    • Use needle nose pliers to pinch and push the button's flanges together, and out of the slot.
  9. DeWalt D28110 Power Switch Replacement: adım 9, 3 resimden 1. DeWalt D28110 Power Switch Replacement: adım 9, 3 resimden 2. DeWalt D28110 Power Switch Replacement: adım 9, 3 resimden 3.
    • Using the J-1 screwdriver, unscrew the power cord wires from the red switch box (located in the back of the grinder).
  10. DeWalt D28110 Power Switch Replacement: adım 10, 2 resimden 1. DeWalt D28110 Power Switch Replacement: adım 10, 2 resimden 2.
    • Disconnect the motor wires from the other side of the switch box.
    • They wires are connected as a sleeve to the flat pin out of the switch box. A firm pull should do it.
Sonuç
3 farklı kişi bu kılavuzu tamamladı.
Kean Wee
495 İtibar
4 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 18-6, Maness Winter 2015 Cal Poly, Team 18-6, Maness Winter 2015 üyesi
CPSU-MANESS-W15S18G6
5 Üyeler
7 adet Kılavuz yazıldı
Bir Yorum
Very clear and concise guide with relevent pictures. Very well done, thank you
Michael Creel - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 40
Her zaman: 5,637
