Giriş
If you realize your battery charger for your drill is not charging, there may be a blown fuse which can be replaced by following this guide.
Neye ihtiyacın var
Remove the four 13 mm, Torx Security #15 screws found on the bottom of the charger.
4 farklı kişi bu kılavuzu tamamladı.
Bir Yorum
Can i get some help in locating the fuse in mt dcb 112 dewalt battery charger i cant found it
