Ana içeriğe geç
DeWalt DC970 Clutch Replacement
Neye ihtiyacın var
  1. DeWalt DC970 Clutch Replacement, Battery: adım 1, 1 resimden 1.
    • Compress the buttons on either side of the battery and lift the drill away from battery.
  2. DeWalt DC970 Clutch Replacement: adım 2, 1 resimden 1.
    • Remove battery from drill.
  3. DeWalt DC970 Clutch Replacement, Drill Assembly: adım 3, 2 resimden 1. DeWalt DC970 Clutch Replacement, Drill Assembly: adım 3, 2 resimden 2.
    • Remove the eight 16 mm, Torx Security #15 screws.
  4. DeWalt DC970 Clutch Replacement: adım 4, 1 resimden 1.
    • Lay the drill on its side and gently lift the top half off it.
  5. DeWalt DC970 Clutch Replacement, Clutch: adım 5, 1 resimden 1.
    • Lift drill mechanism from the drill assembly.
  6. DeWalt DC970 Clutch Replacement: adım 6, 2 resimden 1. DeWalt DC970 Clutch Replacement: adım 6, 2 resimden 2.
    • Twist slightly and pull clutch away from motor.
    • Remove clutch.
Sonuç
4 farklı kişi bu kılavuzu tamamladı.
Jonathan Hamel
663 İtibar
4 adet Kılavuz yazıldı
Ekip
UMass Dartmouth, Team 4-2, Catania Spring 2016 UMass Dartmouth, Team 4-2, Catania Spring 2016 üyesi
UMASSD-CATANIA-S16S4G2
3 Üyeler
13 adet Kılavuz yazıldı
2Kılavuz Yorumları
worthless no info about clutch
bowlweevil - Yanıt
I second the comment from bowlweevil, you dont even open up the clutch...
Hehe - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 4
Son 7 gün: 11
Son 30 gün: 70
Her zaman: 7,337
