Ana içeriğe geç
DeWalt DC970 Forward/Reverse switch Replacement
Neye ihtiyacın var
    1. DeWalt DC970 Forward/Reverse switch Replacement, Battery: adım 1, 1 resimden 1.
      • Compress the buttons on either side of the battery and lift the drill away from battery.
      FixBot'a Sor
      Yorum Ekle
    2. DeWalt DC970 Forward/Reverse switch Replacement: adım 2, 1 resimden 1.
      • Remove battery from drill.
      FixBot'a Sor
      Yorum Ekle
    1. DeWalt DC970 Forward/Reverse switch Replacement, Drill Assembly: adım 3, 2 resimden 1. DeWalt DC970 Forward/Reverse switch Replacement, Drill Assembly: adım 3, 2 resimden 2.
      • Remove the eight 16 mm, Torx Security #15 screws.
      FixBot'a Sor
      Yorum Ekle
    2. DeWalt DC970 Forward/Reverse switch Replacement: adım 4, 1 resimden 1.
      • Lay the drill on its side and gently lift the top half off it.
      FixBot'a Sor
      Yorum Ekle
    1. DeWalt DC970 Forward/Reverse switch Replacement, Forward/Reverse switch: adım 5, 1 resimden 1.
      • Remove the drill mechanism from the shell.
      FixBot'a Sor
      Yorum Ekle
    2. DeWalt DC970 Forward/Reverse switch Replacement: adım 6, 2 resimden 1. DeWalt DC970 Forward/Reverse switch Replacement: adım 6, 2 resimden 2.
      • Disconnect the forward/reverse switch from the trigger by pulling the mechanism out and leaving the switch in the frame.
      • To replace just pull the switch out and put the new one in the opening.
      FixBot'a Sor
      Yorum Ekle
Sonuç
jake
324 İtibar
2 adet Kılavuz yazıldı
Ekip
UMass Dartmouth, Team 4-2, Catania Spring 2016 UMass Dartmouth, Team 4-2, Catania Spring 2016 üyesi
UMASSD-CATANIA-S16S4G2
3 Üyeler
13 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 16
Son 30 gün: 56
Her zaman: 3,167
