Ana içeriğe geç
DeWalt DCF885 Selector Switch Replacement
Neye ihtiyacın var
  1. DeWalt DCF885 Selector Switch Replacement, Battery: adım 1, 1 resimden 1.
    • Press the battery release button at the top of the battery.
  2. DeWalt DCF885 Selector Switch Replacement: adım 2, 1 resimden 1.
    • Pull the battery away from the tool.
  3. DeWalt DCF885 Selector Switch Replacement, Motor Assembly: adım 3, 1 resimden 1.
    • Remove the eight 18 mm Torx Security #10 screws.
  4. DeWalt DCF885 Selector Switch Replacement: adım 4, 1 resimden 1.
    • Separate the two halves of the outer case. Set the empty side down and out of the way.
  5. DeWalt DCF885 Selector Switch Replacement: adım 5, 1 resimden 1.
    • Disconnect the connector from the motor assembly.
  6. DeWalt DCF885 Selector Switch Replacement: adım 6, 1 resimden 1.
    • Pull the motor away from the brush assembly.
  7. DeWalt DCF885 Selector Switch Replacement, Brush Assembly: adım 7, 1 resimden 1.
    • Lift the brush assembly out of the drill case.
  8. DeWalt DCF885 Selector Switch Replacement: adım 8, 1 resimden 1.
    • Pull the armature assembly apart from the brush ring assembly.
  9. DeWalt DCF885 Selector Switch Replacement: adım 9, 1 resimden 1.
    • Pry the two circled connectors apart from the brush ring assembly.
  10. DeWalt DCF885 Selector Switch Replacement: adım 10, 1 resimden 1.
    • The brush assembly is now removed from the drill body.
  11. DeWalt DCF885 Selector Switch Replacement, Switch Assembly: adım 11, 1 resimden 1.
    • Pull the switch assembly up and out of the drill case.
  12. DeWalt DCF885 Selector Switch Replacement, Selector Switch: adım 12, 1 resimden 1.
    • Pull the selector switch out from the outer case.
Sonuç
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 4
Son 30 gün: 9
Her zaman: 650
