Ana içeriğe geç
DeWalt DCS380 Motor Armature Replacement
Neye ihtiyacın var
  1. DeWalt DCS380 Motor Armature Replacement, Removing shoe and boot.: adım 1, 1 resimden 1.
    • Remove the battery before disassembly.
    • Remove the shoe by pressing the yellow button on the left side of the hand grip.
  2. DeWalt DCS380 Motor Armature Replacement: adım 2, 2 resimden 1. DeWalt DCS380 Motor Armature Replacement: adım 2, 2 resimden 2.
    • Remove the two M8x18mm T20 bolts from the front plate.
  3. DeWalt DCS380 Motor Armature Replacement: adım 3, 1 resimden 1.
    • Pull the front of the grip while holding the saw body in place.
  4. DeWalt DCS380 Motor Armature Replacement, DeWalt DCS380 Grip Disassembly: adım 4, 2 resimden 1. DeWalt DCS380 Motor Armature Replacement, DeWalt DCS380 Grip Disassembly: adım 4, 2 resimden 2.
    • Remove the battery before dissasembly.
    • Remove the M3x16mm T10 screw from the back of the grip. Keep it separate from the rest of the grip screws
    • Remove the six M3.63x19 T15 screws from the grip.
  5. DeWalt DCS380 Motor Armature Replacement: adım 5, 3 resimden 1. DeWalt DCS380 Motor Armature Replacement: adım 5, 3 resimden 2. DeWalt DCS380 Motor Armature Replacement: adım 5, 3 resimden 3.
    • Remove the top half of the grip.
    • Turn the saw over and locate the power connectors to the motor.
    • Use needle nose pliers to remove the spade connectors. Take care not to grab the wires on removal, only the end of the spade terminal.
    • Note the polarity for the power connectors and be sure they are not reversed on reassembly.
  6. DeWalt DCS380 Motor Armature Replacement, Motor Armature: adım 6, 2 resimden 1. DeWalt DCS380 Motor Armature Replacement, Motor Armature: adım 6, 2 resimden 2.
    • Remove three M8x18 T20 bolts from the back of the gearbox.
    • Pull the motor case off of the armature.
  7. DeWalt DCS380 Motor Armature Replacement: adım 7, 2 resimden 1. DeWalt DCS380 Motor Armature Replacement: adım 7, 2 resimden 2.
    • Remove two M8x12mm T20 bolts from the bearing retainer.
    • Pull the shaft out of the gearbox.
    • Please note, the brushes will need to be disengaged to reassemble the motor. See the end of the Motor Brush replacement section of this guide for details.
Sonuç
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 6
Son 30 gün: 21
Her zaman: 1,056
