Ana içeriğe geç
DeWalt DCS380 Trigger assembly Replacement
Neye ihtiyacın var
  1. DeWalt DCS380 Trigger assembly Replacement, DeWalt DCS380 Grip Disassembly: adım 1, 2 resimden 1. DeWalt DCS380 Trigger assembly Replacement, DeWalt DCS380 Grip Disassembly: adım 1, 2 resimden 2.
    • Remove the battery before dissasembly.
    • Remove the M3x16mm T10 screw from the back of the grip. Keep it separate from the rest of the grip screws
    • Remove the six M3.63x19 T15 screws from the grip.
    FixBot'a Sor
    Yorum Ekle
  2. DeWalt DCS380 Trigger assembly Replacement: adım 2, 3 resimden 1. DeWalt DCS380 Trigger assembly Replacement: adım 2, 3 resimden 2. DeWalt DCS380 Trigger assembly Replacement: adım 2, 3 resimden 3.
    • Remove the top half of the grip.
    • Turn the saw over and locate the power connectors to the motor.
    • Use needle nose pliers to remove the spade connectors. Take care not to grab the wires on removal, only the end of the spade terminal.
    • Note the polarity for the power connectors and be sure they are not reversed on reassembly.
    FixBot'a Sor
    Yorum Ekle
  3. DeWalt DCS380 Trigger assembly Replacement, Trigger assembly: adım 3, 3 resimden 1. DeWalt DCS380 Trigger assembly Replacement, Trigger assembly: adım 3, 3 resimden 2. DeWalt DCS380 Trigger assembly Replacement, Trigger assembly: adım 3, 3 resimden 3.
    • Take note of the position of the battery tension spring and safety switch before removal.
    • Lift the trigger assembly out of the grip.
    FixBot'a Sor
    Yorum Ekle
Sonuç
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 7
Son 30 gün: 45
Her zaman: 1,895
